0 Cylinder Piston kits
0 Another use for your Iornhead engine.
0 1967 XLCH stroker project
5 Did you go back to an OEM plungers seat? Like it?
0 Feeling in trouble.
0 Diagnostic help
Last Post: BradX13
0 If you have European tilt
7 Long Road Trip advice
Last Post: 38mini
0 HAMMERPerf 90" In the Works
Last Post: MatHormell
Last Post: kkbii
0 first harley- help!!
Last Post: r4fthrs
0 Engine turns but no spark at the plugs. 05 883L
0 PACK YOUR BAGS SALE! Take 10% off 'Voyager' Series Luggage
Last Post: BILLETPROOF
Last Post: lo-rider
0 79 side cover/oil tank annoyance
Last Post: runingmouse
0 Will you help out The XL Forum?
Last Post: bplinson
0 spoke nipple tool?
0 Seat manufacturers closest to Corbin?
Last Post: Jollly Rogers
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: night-train
0 Not charging issue!
0 Back in Sporty Land
Last Post: TurkeyRun
Old 7th April 2018
hoboandy hoboandy is offline
Sportster/Buell Model: Roadster XL1200CX
Sportster/Buell Year: 2016
hoboandy is a splendid one to beholdhoboandy is a splendid one to beholdhoboandy is a splendid one to beholdhoboandy is a splendid one to beholdhoboandy is a splendid one to beholdhoboandy is a splendid one to beholdhoboandy is a splendid one to beholdhoboandy is a splendid one to beholdhoboandy is a splendid one to beholdhoboandy is a splendid one to beholdhoboandy is a splendid one to behold
Originally Posted by sportytrace View Post
Others have suggested contacting Hammer perf, even just their common mistakes section on installing kits might provide some guidance before calling them: https://www.1250kits.com/ttinstallkit.shtml#More
Thanks for this link, it was very insightful. I'm starting to think it would have been a good idea to go ahead and change the displacement to something slightly larger in the fuelpak app seeing as how I am pulling quite a bit more air. I would have rather needed to adjust for a too rich engine than a too lean engine to be on the safe side. Thanks again for the great replies.
Old 16th April 2018
cvaria's Avatar
cvaria cvaria is offline
Sportster/Buell Model: bike
Sportster/Buell Year: 1900
cvaria is an unknown quantity at this point
foolpak strikes again
1. 2007 XLCN 2. 2012 FXDWG X. RIP - 2013 FXDWG
Blue Scoot's Avatar
Blue Scoot Blue Scoot is offline
Sportster/Buell Model: XL883N
Blue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant futureBlue Scoot has a brilliant future
Sorry to hear about your troubles! Hope you can get everything worked out and back on the road.
What's the next step? Keep us posted on the progress.
2013 Iron 883 currently @84k miles and counting...
Hey guys, I've gone with the Hammer 1250 flat top pistons and cylinders. Still going to be using the SE 575 cams as well. I've put it all together and so far it seems to be working well. Ive also been watching the temperature closely. My one issue is that I have a ticking or tapping noise in the top end on the left side. It doesn't happen at idle, only when above 2000 rpm or so. It is very noticeable when decelerating in gear (little exhaust noise). Seems quiet as it slows and ticks from about 3000 down to 2000 rpm. I went ahead and got new lifters just in case the old ones had a bunch of metal in them and I've checked all the clearances and nothing is hitting. I used a dremel to clean up some areas in the rocker boxes as well where the springs may have been rubbing. I even went as far as to put the stock cams back in it and it still ticks. I also retarded the timing a couple degrees in those ranges and still no change.
From here I'm thinking it could be the valve springs. Getting up to nearly 500 degrees may have weakened them and they can't keep up with the cams.
Other possibilities - I need adjustable pushrods, broken or binding valve spring, sticking or bent valve, loose or worn valve guide. Not sure if these would cause that but I will be tearing it apart again tomorrow and will let you guys know what I find.
To give this some background, it did not tick after it was initially built (before it overheated). After about the first 150 miles it began to tick and got worse the more I drove it. This makes me think it is something due to the fact that it overheated (like springs, lifters, metal in oil) and not something like clearance issues. Again, it did it with the stock cams too. Now after the second rebuild the tick remains.
Any advice on this is much appreciated. Thanks all.
rejeanprimeau's Avatar
Get some rocker sleeve for the bolts, they will get rid of the ticking.
Here is a link to the rocker lockers mentioned above-
http://www.dkcustomproducts.com/spor...-dk-rl-spt.htm
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
