0 WTF Happened
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
0 Cylinder Piston kits
Last Post: jordan1200
0 05 and 73
0 What is this?? 07 efi 1200 weird box
Last Post: Hank21113
0 Brake light stays on
Last Post: jammantoo
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
0 Tool Roll Help
Last Post: ReddTigger
Last Post: blindfredy
0 S.Fla. shop
Last Post: the cowboy way
0 Back in Sporty Land
Last Post: skien
Last Post: The Crusher
Old 28th December 2017
johnwesley's Avatar
johnwesley johnwesley is offline
Sportster/Buell Model: xl1200s
Other Motorcycle Model: klr650, tiger 955i
johnwesley has much to be proud ofjohnwesley has much to be proud ofjohnwesley has much to be proud ofjohnwesley has much to be proud ofjohnwesley has much to be proud ofjohnwesley has much to be proud ofjohnwesley has much to be proud ofjohnwesley has much to be proud ofjohnwesley has much to be proud ofjohnwesley has much to be proud ofjohnwesley has much to be proud of
Default Fxdi exhaust
have a fxdi looking to replace the freedom pipes that are on it now. Would like a 2/1 that won’t break the bank but preform decent and work when time comes to upgrade to a 98” build.
The 3 pipes below are what I’m looking at. What’s your thoughts on which one preforms best? Bike is an 05
https://cimg6.ibsrv.net/gimg/www.hdf...f30185703.jpeg
Presently I have some loud pipes that aren’t that good at making power
I’ve asked in other Forums, but this one seems to be the best with advice, not sure how much BT peeps are in here
Xl2000s 1250 kit with 30* pistons. JH 570 cams, thunder header exhaust
Old 29th December 2017
jammantoo's Avatar
jammantoo jammantoo is offline
Sportster/Buell Model: 48
Sportster/Buell Year: 2016
Other Motorcycle Model: Dou-glide
Other Motorcycle Year: 63
jammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond repute
Properly tuned, the V&H big shots 2 into 1 is a great pipe for sound and power.
Join the PEANUT CLUB, it gives you an excuse to stop and smell the roses
