0 Shoulder rotator cuff problems
0 Brake Problems
Last Post: rog
0 Fat Bob tanks on a 93 Sportster
0 Best Bang for your Buck Exhaust option?
0 Slip on muffler
0 Belt keeps moving to the right, replace transmission sprocket
Last Post: RoelVP
0 Wiring Diagram in autocad
Last Post: forqueue
0 Metzeler Cruisetec
0 Surging/lurching at low speed?
0 Sportsterpedia Progress
0 23 years old just bought a 1980 XLH
0 72 metal shavings in oil?
0 answer with a question game
Last Post: b0fh
7 Rear fender interchangeablity.
Last Post: 883Roadster
0 Air or Co2 shifters
0 Regulator battery draw
0 Best Cams for a XL1200 Roadster?
0 The Official SuperLow Thread... Let's See 'Em!!
Last Post: bambambam
0 budget sportster rider
Last Post: heyshott 81
leprechaun50 (69), Hammerhead (56), c.wissler (49), kjy026 (47), RoseLady (47), Jayjunior (42), hradek422 (31)
  #41
Old 5 Days Ago
CyclesInc's Avatar
CyclesInc CyclesInc is offline
Sportster/Buell Model: A Few
Sportster/Buell Year: many
CyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud ofCyclesInc has much to be proud of
Looks like Mainshaft 3rd or Countershaft 2nd. Ouch!
Old 5 Days Ago
Darkseacret Darkseacret is offline
Sportster/Buell Year: 77
Darkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to allDarkseacret is a name known to all
Is my next step to pull motor and start tearing into clutch/ tranny ?
Old 5 Days Ago
frogg_nutts frogg_nutts is offline
Sportster/Buell Year: 72
Other Motorcycle Model: XLH
Other Motorcycle Year: 80
frogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to beholdfrogg_nutts is a splendid one to behold
No.
Buy this one.
https://greensboro.craigslist.org/mc...852883026.html
Frog
Old 5 Days Ago
Your cheapest fix is to replace the motor with a used one.
Repairing yours can easily cost as much as the purchase of another bike.
As to the transmission I will not run either of the factory 20 tooth gears as they are grenades as you have found. The way the gears are made leaves very narrow margins accompanied by stress risers adjacent to the margin which facilitates splitting.
Andrews Products makes replacement gears that are billet (stronger) instead of forged and also the stress risers are eliminated by a radiused corner in the pockets.
The (2) 20 tooth gears are
35750-56A countershaft 2nd (17-8241 andrews)
and
35305-56A mainshaft 3rd (17-8244 andrews)
Old 5 Days Ago
Sportster/Buell Year: 1974
needspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant futureneedspeed has a brilliant future
Obviously both the engine and transmission need to come out but not necessarily in that order. Sometimes its easier to loosen the tight nuts with it in the frame and pulling the transmission first makes it all lighter. Pulling one or both heads while in the frame makes it even lighter.
It's up to you.
Old 5 Days Ago
doodah man's Avatar
Absolutely use your frame as an engine stand. Makes life so much easier.
Old 5 Days Ago
Flame__'s Avatar
Flame__ Flame__ is offline
Sportster/Buell Year: 1989
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2000
Well chit.
Knees in the breeze.
Gamertag, PS4: Bikerdude__
