0 Brake Problems
Last Post: rog
0 Fat Bob tanks on a 93 Sportster
0 Best Bang for your Buck Exhaust option?
0 Slip on muffler
0 Belt keeps moving to the right, replace transmission sprocket
Last Post: RoelVP
0 Wiring Diagram in autocad
Last Post: forqueue
0 Metzeler Cruisetec
0 Surging/lurching at low speed?
0 Sportsterpedia Progress
0 23 years old just bought a 1980 XLH
0 72 metal shavings in oil?
0 answer with a question game
Last Post: b0fh
7 Rear fender interchangeablity.
Last Post: 883Roadster
0 Air or Co2 shifters
0 Regulator battery draw
0 Best Cams for a XL1200 Roadster?
0 The Official SuperLow Thread... Let's See 'Em!!
Last Post: bambambam
0 budget sportster rider
Last Post: heyshott 81
0 Re tap bleed screw hole
leprechaun50 (69), Hammerhead (56), c.wissler (49), kjy026 (47), RoseLady (47), Jayjunior (42), hradek422 (31)
View Poll Results: Stock Spring plate, has it gone bad on you
Solid Mount- (2003 and earlier) Still Good (below 50k) 54 19.93%
Rubber Mount (2004+)- Still Good (below 50k) 92 33.95%
YES -Solid Mount 10,000-20,000 5 1.85%
YES -Solid Mount 20,000-30,000 3 1.11%
YES -Solid Mount 30,000-40,000 5 1.85%
YES -Solid Mount 40,000-50,000 3 1.11%
YES -Solid Mount 50,000 + 3 1.11%
YES -Rubber Mount 10,000-20,000 24 8.86%
YES -Rubber Mount 20,000-30,000 28 10.33%
YES -Rubber Mount 30,000-40,000 11 4.06%
YES -Rubber Mount 40,000-50,000 4 1.48%
YES -Rubber Mount 50,000+ 5 1.85%
No Solid Mount 50,000+ 19 7.01%
No Rubber Mount 50,000+ 15 5.54%
Voters: 271. You may not vote on this poll
  #301
Old 6 Days Ago
Nibelungen's Avatar
Senior Bike Builder
Originally Posted by rejeanprimeau View Post
Looking at the teeth of the kit in the lower picture, the friction disks are the old style type.
sharp eye...
congrats
i already had done some intel work about that... and had found the same...
then i have forgotten...
lesson of history is that it's never really over, not today, certainly not tomorrow...
Old 3 Days Ago
r4fthrs's Avatar
r4fthrs r4fthrs is offline
Optimist with experience
Sportster/Buell Year: 07
r4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond repute
the slight squeal is not a cons or a fault in the design...is the price for not having anymore a spring plate...or even a judder spring...that is a clutch for racing... with kevlar inserts...if anything her cons could be a bit less adjustability...but i can live with that (actually i live over 5k revs)...
I replaced my clutch with the Barnett kit with extra plates and used my stock clutch spring and I have never experienced a squeal. Has been about 5 years now and clutch works great. Smooth, positive release and no slippage. I wonder why some experience that issue and others don't?
Armed you are a citizen, unarmed a subject.
Fear the government who fears your guns.
An armed society is a polite society.
Old 3 Days Ago
Tomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant futureTomcatt has a brilliant future
I went thru this. I have a NOS 2017 XL1200C. As delivered the clutch drug BADLY. With the bike in gear and the clutch pulled in (engine off) it was a major effort to push the bike. Neutral was next to impossble to find. I dumped the primary / transmission oil and filled with Redline 75w90NS and it got a little better. I opened the primary and replaced the grenade plate with 2 OE steels and an OE friction. Put in a 7200B release brg too. Filled it with Redline D6 ATF.
Now the clutch screeched occaisionally. As I've put some miles on it the screech has gone away and the clutch drag has decreased to normal.
No more screech, no more clutch drag, good clutch apply, Redline D6 in the primary / transmission.
Go figure.
