0 Issue that has me stumped
0 Carb, manifold issues
Last Post: davixlrtt
0 DK's Definitive Ride Report - Some of the Best Scenic Roads Out West - Tons of Photo'
9 MAP code problems
0 How old are you?
0 Which cam?/ 551 or 570/Why?
Last Post: Nate.evans
Last Post: jcro61
0 Any here have experience with B cell Luekemia?
0 Analog Tach on 2004-2013 Sportster with OEM Digital Speedometer
Last Post: robistro
3 Ironhead Pictures Thread
Last Post: DirtyHarry68
0 ‘68 XLCH...transmission
0 1993 sportster / loud grind no go
Last Post: Nightrain
0 Question about dynamic timing a 2000i
Last Post: jordan1200
0 THE Trainspotting Thread
0 Cafe' Image thread WTFN
Last Post: tigger
Last Post: Blowupster
0 Puked oil or primary fluid
Last Post: painterdude923
Last Post: lugster
0 Honda Nostalgia
Last Post: jzink0883
0 The country store
Last Post: lugster
0 Dyna 2000i data information pulled
0 Wisamic headlight comparison
Last Post: Legion Prime
0 Switch controls.
Last Post: Serious Blac
0 Question for the ol’timers
Last Post: Yakcm2
0 Bannana Caliper 73 XLCH- no brakes?!?
  #731
Old 1 Day Ago
cycowrencher's Avatar
NED
Impact 1250
S&S superE
66 inch wb
715lbs
Old 1 Day Ago
rocketmangb's Avatar
Nice pass !!!!
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 1 Day Ago
jcro61 jcro61 is offline
jcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud of
Same engine setup as last post
11.754 @ 111.39
Picked up 2-3mph in the 1/8th and 2mph in the 1/4
Bike would go pretty damn good if it had the nut to 60’
this isn't just a trend homie, it's a lifestyle...
Old 1 Day Ago
Vohnsen Vohnsen is offline
Totalt weight ca. 615 lbs
64" wheelbase
Bone stock motor with only Ultima ignition and straight pipes.
I race at a local street race track without any prep.
best ET 7.761 at 1/8
https://www.youtube.com/nikolaiownz - Homemade dragbike with Stock XL1200 '98 engine.
Old 1 Day Ago
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
[QUOTE=cycowrencher;5687237]11.18...
NED
Impact 1250
S&S superE
66 inch wb
715lbs
Nice pass, looks like she’s laying down on the back half. Is it consistent?
Old 1 Day Ago
Its fairly consistent... I'm still not geared correctly. Need to go up 3 more teeth on rear or drop to 48 and do 30 tooth primary. I'm at a 56 rear now...
