0 1960 XLCH in the UK
Last Post: chilly
0 Greetings from Denmark
0 88ci Sport Rod
0 removing clear coat on fork lowers
Last Post: jazzman
0 Howdy ya'll
0 Another from the Phoenix area
0 Hello from Tampa, Fl
Last Post: JonesL
0 48 O2 sensor?
0 Phoenix AZ
0 Hello from Philadelphia, Pa
Last Post: ronccc
0 Starting issues (No Spark)
Last Post: ronccc
Last Post: marcusorelius
0 [Ignition] Points in a 2000n evo
Last Post: lostjohnny
0 back to factory clutch
0 Battery melt down
Last Post: stick shift
0 Resto-Repair 84 ironhead
Last Post: Robyart
0 Getting Hammered
Last Post: Bryan83taco
0 1968 Vin number help
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
Old 2nd March 2013
DonChicago48's Avatar
DonChicago48 DonChicago48 is offline
DonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of lightDonChicago48 is a glorious beacon of light
Default Building a 90-inch Sledge Hammer
I got some good news recently. I talked to Dan at Hammer Performance and my engine work will soon be completed. I'm looking forward to assembling it and getting it started so I can ride again.
I'm about to assemble an '03 1200 engine that will have 90 cubic inches (1474 CC) displacement. The Axtell Cast Iron Cylinders have a 3.875" bore, the largest bore diameter supported by a stock Sportster. It uses reverse-dome pistons with 30-degree squish area and 10.9:1 compression.
The '04-'06 heads have the Hammer Performance Sledge porting with 1.940/1.615 Intake/Exhaust valves and competition springs, retainers, and keepers. The engine is set up for a Hammer 600 cam set, but by shaving the heads approximately .030", it will support the Hammer 660 cam as well. It is equipped with the earlier pinion gear so installing the 660 cam should entail only modest changes.
The engine will be fed by a Mikuni HSR48 carb through a Hammer Performance intake manifold for now. It will use my existing Arlen Ness Big Sucker II Air Cleaner.
Murphy's Law applies.
The 9 scariest words in the English language: "I'm from the government and I'm here to help."
Old 2nd March 2013
NI-STR's Avatar
NI-STR NI-STR is offline
Sportster/Buell Model #2: Nightster
NI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to beholdNI-STR is a splendid one to behold
Hope your current seat is a deep bucket. Your gonna' need it!
Should be a "ton o fun"!
Old 2nd March 2013
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Good stuff!
If you'd like I can probably shoot some engine porn pics for you, I'll be at the shop today.
Click Here to Contact Me
Old 2nd March 2013
ted's Avatar
ted ted is offline
Senior Master Bike Builder
Sportster/Buell Model: 883-1380cc hot rod
Sportster/Buell Year: 87
Sportster/Buell Model #2: wife's 883-1200
Sportster/Buell Year #2: 87
ted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to beholdted is a splendid one to behold
Good stuff!
We all like porn..
Still crazy after all these years.
Late 87-883 Hugger/1380cc (84") conversion. Too many cool parts to list. Built engine on a fresh set of cases, so conversion might not really describe it. Estimated near 115 hp.
Early 87-883/1200 conversion. Wife's bike. SE heads, 1200 flat pistons, 40" Drag Pipes, everything else stock.
"Wise men speak because they have something to say; Fools because they have to say something."
Plato
Old 2nd March 2013
Sleeper Sleeper is offline
Sportster/Buell Model: XL883R
Pictures would be good.
Trick heads and pistons with a 10.9:1 compression ratio and a HSR48 sounds like you ain't fooling around.
What year(s) did they use that pinion gear? Is it OEM or aftermarket?
Old 2nd March 2013
After this build, this will be one of the fastest bikes I've ever ridden. The seat does provide good rear support and I've not skimped on the suspension, brakes and drive train.
Old 2nd March 2013
Good stuff!
Yes Aaron please do. I have looked through your vast list of engine photos and not found a set of heads quite like mine. Mine have 1.940/1.615 valves, dual spark plugs, and 30 degree squish milled for the 3-7/8" bore.
Old 2nd March 2013
aswracing's Avatar
The Sledge 660 cams are made for the 91-99 pinion gear only. This is common among bigger cams as the 91-99 has bigger, presumably stronger teeth. So you look at the big grinds from Andrews, Wood, RS, etc, and they're only available in the 91-99 pinion design.
The Crush 600 cams are available in either the 91-99 or 00-up style. Don't just planning for the future by doing the motor with the 91-99 style right off the bat.
Old 2nd March 2013
I believe it was used from '91-'99. If I recall, the downside to running the earlier gear is that those pinions came in various sizes so ideally, the pinion and cam gear should be fit together to match. I suspect the older gears are a bit noisier as well.
I'm not planning to keep the Mikuni carb for very long. I am working on adapting an aftermarket EFI system to the Sportster. That project thread is here.
Old 2nd March 2013
onebrkbstrd's Avatar
onebrkbstrd onebrkbstrd is offline
Sportster/Buell Model: xl1200l
onebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond reputeonebrkbstrd has a reputation beyond repute
It's going to rock. Color me jealous.
