0 question for our machinists
Last Post: Yakcm2
0 Fact or fiction?
0 Race tracks are harsh environments
0 You can't tour on that!!!
Last Post: RDHenley
Last Post: herostar
0 Black Friday/Cyber Monday Showoff Thread
Last Post: herostar
0 XLCH Plunger Seat Kit
Last Post: FatboyBill
0 hi all
Last Post: early iron
0 Swingarms
0 the roadster make more power ?
0 supply oil line seeping
0 Question on priming motor for kickstart
0 Interview of My Expieriences Riding in the Iron Butt Rally
0 Hydraulic Lift For XL
0 3.5" straight riser
0 Cometic Air Cleaner Gasket?
0 Fork Upgrade to 39mm. Is This Possible/Wise
0 Very Loud Backfiring (among other things)
Last Post: Nacs
Old 11th August 2019
rathawk rathawk is offline
Sportster/Buell Model: 1200c
Sportster/Buell Year: 97
rathawk is just really nicerathawk is just really nicerathawk is just really nicerathawk is just really nicerathawk is just really nicerathawk is just really nicerathawk is just really nicerathawk is just really nicerathawk is just really nicerathawk is just really nicerathawk is just really nice
Originally Posted by harley506d View Post
thank you!
Old 15th August 2019
hey all, I got the screw out and was going the cheap route and took the screw to the hardware store. I thought it was an 8x32, an 8x32 nut threaded over the OG carb screw, but when i took the screws home, they would not thread into the carb. Does anyone know what size screw these are?
Thank you,
wedge's Avatar
wedge wedge is offline
Thank you,
Metric. I forget the size, but I have a bag of cap screws in different lengths for doing the CV carbs with.
Thank you,
The Sportsterpedia has your info:
http://sportsterpedia.com/doku.php/t...nge_the_screws
They are 4mm threads - For Hex Heads use a 3mm hex wrench
(For Button Head, they need a 2.5mm hex wrench)
Note that the top bracket has a longer screw:
Summary List:
4ea - 4mm x 16mm x .70TPI for Float Bowl
3ea - 4mm x 16mm x .70TPI for Top Diaphragm Cover
1ea - 4mm x 20mm x .70TPI for Top Diaphragm Cover at Throttle Bracket
3ea - 4mm x 10mm x .70TPI for Accelerator Pump
Summary List:
Thank you!
Thank you!
Found some!
Sent from my SM-G930V using Tapatalk
