0 who rides with a Flyscreen (or similar) AND an open face helmet?
0 Tools
0 New member
0 Burns Stainless custom exhaust
Last Post: rubine
0 Mac exhaust
0 6 speed
0 2012 883 miss that comes and goes
Last Post: tussuck
Last Post: oupa
Last Post: 83XLX
0 More oil return questions
Last Post: Scott
0 883 cc >> 1200 cc big bore conversion
Last Post: lovevoodoo
Last Post: HDCUSTMBUILD
0 Brake pedal adjustment on 09 Custom
7 Ironhead yes or no
0 forged pistons?
0 Sportsterpedia Progress
0 IH rearsets and giant stud
Last Post: dewjantim
0 1250 break in map for tc88a
0 TC88A EEPROM or FLASH
3 Shaky Dave Recovery
0 Getting Hammered
Last Post: Bryan83taco
0 Power outlet
Last Post: RDHenley
Old 17th August 2019
broknluck broknluck is offline
Sportster/Buell Model: 883
broknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud of
Default New Gas Tank or Cat Litter Jug.
I am looking for a new Gas Tank or Fuel Cell for my 1999 Carberated Sportster.Im considering a larger than stock size;But I found when said Something Fits does not always mean Everything Fits or Works.Many tanks are without the vent tube thing on the right side.My other concern is correct Petcock Hole Size??? Even with the after market King Tank I see some fitting issues. Any suggestions on a bolt on tank.I once put a Polyurethine ? tank on a racing bike many years ago.Id rather hang a plastic jug on it than waste money on a non fitting head ache.
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
I've been looking too. The aftermarket 4.1 gallon tank requires a vented cap.
If you just need a 3.3 king tank, there are plenty of good used tanks for sale. Maybe even in the same factory color.
Sleepy Labeef rides again!
Ill get a new tank .
Old 20th August 2019
I got a Porkster 4.2 tank,it fits the 1999 Sportster just fine but stock gas caps do not fit.
Old 24th August 2019
ron521's Avatar
ron521 ron521 is offline
Sportster/Buell Year: 1991
ron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really nice
I can tell you that the "V-factor Legacy Gas Tank 81062" on the Dennis Kirk website (https://www.denniskirk.com/v-factor/...prd/189122.sku)
did NOT work on my 1991 XLH.
Specifically, without the petcock installed, the tank would fit fine on the frame, and the mounting holes would line up properly front and rear. However, the bungs projected far enough out that the factory petcock could not be installed on either side. If installed on the right, the petcock hit the top of the carb diaphram cover. If installed on the left, the petcock hit the top motor mount. With the petcock installed on either side, the rear tank mount could not be made to line up with the holes in the frame.
Looking at other petcocks in the DK website, nothing appeared to be significantly shorter than what I had, and I didn't really want to buy something else to make it work when the tank was advertised on Dennis Kirk's page as "Exact Fit".
It really is a shame, because without the petcock installed, I liked the lines of the tank itself (something like a cross between the standard peanut tank and an old Triumph tank) as well as the way the tank sat low over the engine, and blended in with the lines of the frame and the seat. Everything LOOKED like it was designed to work together, and the tank had a very useful capacity of almost 4 gallons...except for the petcock issue. I could make it work with a tank lift, but that would break the lines and spoil the appearance.
So...I'm also looking for other alternatives, and will be following this thread to see what others come up with.
A great pleasure in life is doing what people say you cannot do.
Old 3rd September 2019
The 4.2 Porster fits my 99 sportster very well .Also Ive seen a metal hold down strap set up if your tank if it dont line up with the bolts
Old 10th October 2019
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond repute
Bungs are cheap so if you weren't able to return the tank or like the lines you could have a local weldor install one where you like and grind the existing bungs near flush then weld them shut. A bit of clean round bar or cutoff bolt makes a tidy plug. Tack plug to weld filler wire for a handle, insert plug into what's left of the old bung, tack then finish weld and smooth with flap disc. A step drill but doesn't grab sheet metal if you want to drill it yourself and step bits are insanely useful to own. Blow out tank with compressed air to ensure no crumbs.
It's simple, easy work. Show your weldor this post.
