0 question for our machinists
Last Post: Yakcm2
0 Fact or fiction?
0 Race tracks are harsh environments
0 You can't tour on that!!!
Last Post: RDHenley
Last Post: herostar
0 Black Friday/Cyber Monday Showoff Thread
Last Post: herostar
0 XLCH Plunger Seat Kit
Last Post: FatboyBill
0 hi all
Last Post: early iron
0 Swingarms
0 the roadster make more power ?
0 supply oil line seeping
0 Question on priming motor for kickstart
0 Interview of My Expieriences Riding in the Iron Butt Rally
0 Hydraulic Lift For XL
0 3.5" straight riser
0 Cometic Air Cleaner Gasket?
0 Fork Upgrade to 39mm. Is This Possible/Wise
0 Very Loud Backfiring (among other things)
Last Post: Nacs
Old 25th August 2019
biker551 biker551 is offline
Sportster/Buell Model: 883xlh
biker551 is an unknown quantity at this point
Default cylinder screw torque specs.
Hello all, trying to find out the torque specs for the cylinder screws on my 2000 883 sporty. they're kind of rusty, so I figured I'd changed them. is this pretty straight forward, or not? Thanks
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
Welcome to the forum.. Let me start off by saying that a service manual is a "must have" if you are planning to do any assembly/disassembly on your bike. There is not only torque specs in them but, most important, torque sequences.
also consider that some fasteners are torque first then so many degrees rotation. this is based of stretch and not torque force which can vary for many reasons and i believe the bolts are such
FSM please
one OUCH!!!! to avoid is oil on the threads can lead to false reading and/or cracked parts
FSM please
Old 30th August 2019
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
FSM please
Except for Evo head bolts. Lube the threads of the bolt and stud, and flange surface, with a light coat of oil. If not, you'll get way undertorque on the head bolts.
Don't overdo it though, no need to hydrolock it.
http://i.imgur.com/Oe4Ttw0.pnghttps://i.imgur.com/AFv3AMo.jpg?1
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
FSM please
FSM please
These do require a thin coating of oil. Key word being thin. And as was mentioned, there's a specific sequence to torqueing these down.
Are you leaving the old gaskets?
ReddTigger's Avatar
if you're talking about the head bolts, those are the 12 point shanked
like these..
then you will need to replace the head gasket at a mininum.
if you're talking about the studs.
like this
then you are going to need base gaskets as well.
the studs also should come with lock patch on them otherwise use a red loctite.
cylinder head bolt torque specifications typically rely on the direction for the head gasket manufacturer.. Cometic, HD, james have their own specs.
if they're just ugly. put a cap on them for a lot less money and headache..
States I've Ridden in
71.3 hp 70.8 tq
Old 31st August 2019
rejeanprimeau's Avatar
rejeanprimeau rejeanprimeau is online now
No leak, don't touch, cosmetic, use a little silver nail polish.
Sportster/Buell Year: 1991
+1
You can only get at two on each cylinder, without removing the rocker box assembly as well. Not worth the trouble unless you have other issues.
I'll bet mine are a lot more rusty than yours, after being on the coast for 29 years. I call it "patina."
John
