0 Help me identify this bike
0 Clutch cable help (length)
Last Post: Blackbenny
4 greetings from quarantine!
Last Post: robbie202
0 Show us the different versions of your bike!!
Last Post: lmarshall73
0 Anyone tune for and use E85?
0 The forum got talent
0 Low Profile Scissors Lift
Last Post: ReddTigger
0 MC lift table modification
0 Who runs 70wt. oil
0 Leineweber camshaft
Last Post: mrmom9r
0 2006 883 pops the maxi fuse after battery change
0 2016 Oil Drain Hose Has Cracks
Last Post: joes95bobber
Last Post: jazzman
0 68 XLCH - Insight Plz
Last Post: drumbrake
0 Brad Penn, catalytic converters and EFI sportster
0 Floating front disc
0 TSM / TSSM / HFSM - How to disable alarm and/or replace unit
Last Post: 83XLX
View Poll Results: What weight fork oil do you use
5w 39 9.44%
10w 87 21.07%
15w 113 27.36%
20w 40 9.69%
30w 16 3.87%
standard weight HD 76 18.40%
Screamin eagle HD 52 12.59%
Multiple Choice Poll. Voters: 413. You may not vote on this poll
Old 17th June 2007
snowman's Avatar
snowman snowman is offline
Went to SE heavy and it still bottoms out.... Gonna have to break down and get new springs...
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Old 17th June 2007
gronk62's Avatar
gronk62 gronk62 is offline
mostly harmless.. (sssm)
gronk62 has disabled reputation
Yep. Springs are what hold the bike up. Oil helps to control the movement.
Old 24th June 2007
racerwill's Avatar
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
when I got the Metzlers I liked the cornering so much I raised the rear an inch, leaving the front lowered and changed from 15W to 20W......
a little stiffer, but I like it.
Ww
master wizard
RIP Mr Jimi
"All The Way"
Old 30th June 2007
Lone Wolf in Canada's Avatar
Lone Wolf in Canada Lone Wolf in Canada is offline
Sportster/Buell Model: XLC Custom 1200
Lone Wolf in Canada is on a distinguished roadLone Wolf in Canada is on a distinguished roadLone Wolf in Canada is on a distinguished road
Bel Ray 15 w.
I found a Big difference from the stock weight.
2005 Custom 1200 Sierra Red & Silver Pearl
Old 5th July 2007
rx3732's Avatar
rx3732 rx3732 is offline
Sportster/Buell Model: '06 883 Custom
rx3732 is on a distinguished roadrx3732 is on a distinguished road
I weigh 150lbs, so I'm not sure if I should go w/ the 15w or the 10w.....any suggestions? I'll be putting standard length progressive springs on in a few days.
Buying the bike was the cheap part....the "extras" are what costs me!
Old 6th July 2007
mid30's Avatar
mid30 mid30 is offline
Sportster/Buell Model: 1200r
mid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nice
how do you make them softer then softer the tighten them back up?
Old 6th July 2007
XLFREAK XLFREAK is offline
XLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this point
Bel Ray 15W with Progressive springs
Old 9th July 2007
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
I'd leave them alone unless they aren't working for you. It's usually the springs that suck.....1-1/2 -2 " sag
Stuff: YES
Old 9th July 2007
BWP 5p's Avatar
Spring rates......and pre-load spacers on top of the springs
Old 9th July 2007
Gone Gone is offline
went to put in 15w and the motorcycle shop said you had to rebuild the forks if you change the oil. O dummy me was just going to take out the phillips head screw and push up and down on the handlebars until the oil stopped coming out and put 9oz. of 15w oil in the the top of the forks. they said you can't do this because it messes up the seals and dampening valves. Dave
