0 In a crash: Lucky to be alive
0 Misfire 02 883
Last Post: Thegen58
0 Why I don't have a HID Headlight Poll
0 answer with a question game
Last Post: 72 Ironhead XLH
0 What engine oil do you use?
Last Post: Clevspeed
0 headlight upgrade
Last Post: Dcoff
5 Harley T-Shirts
0 New handlebar wiring harness 81XLH?
0 Head gasket leak.
Last Post: lucifer_mr2
0 (Do) (Are) Loud Exhausts__________.
Last Post: Eddieblz
0 Ever been pulled over?
Last Post: Sprtstr1200s
0 Regulator battery draw
6 Calling all musicians
Last Post: Eddieblz
0 Ran out of gas.
14 Post your Bike in a Cemetary Pic
0 Safe Max Rev Limit stock engine Roadster 2017
Last Post: eduardox23
0 '04+ Starting Issues, Do You Have Them? - Poll
0 A Day in the Life...
0 Starter problem
WinXP (68), Maggie (62), grancan1 (54), SRKASM (48), metalmessiah, o113attitude (44), stinkynate (36), wingman_214 (35)
90ci, big bore, engine builder, hammer performance, patriot defender
  #1051
Old 20th February 2017
jkinkade jkinkade is offline
Sportster/Buell Model: XLH 88" 2003.
jkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant future
I have never used an extended swing arm , but i think it was wise to get the best!! i wonder if it will effect traction or need different rear shock set up? i raced a guy once at track this guy had his first race on a bike with very long swing arm, but he normally raced a wheelie bar race bike, when we got the go light he went up in the air a long way.
cheers
rubine rubine is offline
Sportster/Buell Year: Bits
Other Motorcycle Model: '00
Congrats on the house bro. Nothin like owning your own pad, as long as the mortgage is manageable. Then build that monster garage!
Old 21st February 2017
MatHormell's Avatar
MatHormell MatHormell is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: Buell XB12R
Other Motorcycle Model: Yamaha
MatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond repute
cheers
Should be a major improvement in traction, using the 180 tire on the 6" wheel, rather than the 130 before. Im only 2" over stock wheelbase in the most forward position of the axle, But I was getting use to launching at stock WB, so this should only help, and can go to 4 1/4 over stock w/b for the track. I sold my Progressive 970's to cover the new Axtells cylinder and finally drive sprockets I need. Not sure what shock I will end up using, Im close to getting a 1/2 off set of legends shocks, so may end up with those on it.
Thanks man, Ya its been a prcoess but we finally found what we were looking for within our budget. Big plus to this house is its not in a HOA, ( home owners association). Which is hard to come by in North Texas. The house has a small shop in the side yard, which I plan to build off of, Will make for a nice small shop, and get all my shit out of the garage lol.
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HAMMER PERFORMANCE Intake Manifold
HSR 48 Miunki
XR1200 Crank Conversion W/ Case Mod 34T
HAMMER PERFORMANCE Sledge+ Head Work
2.020" Intake and 1.630" Exhaust Valves
Conical Valve Springs
S&S Premium Lifters
HAMMER PERFORMANCE Billet Push Rod Bases
Barnett Clutch Hub With Scorpion Clutch
Dynatek 2000i
R&D MOTORSPORTS- TRANSMISSION WORK-REM ISF
WorldWideBearings
Patriot Defender Exhaust
Old 25th February 2017
MatHormell's Avatar
Sent from my SAMSUNG-SM-G890A using Tapatalk
Old 2nd March 2017
MatHormell's Avatar
Mounted up the rear brake caliper, Its going to work perfectly, but im going to have to turn down the wheel spacer a little bit so the disc will center better. Havent had time to do anything else, and probably wont for the next few months. Motor parts should be back soon, might and hope to be able to get the motor back together before the move but thats not looking promising. Packing and moving my garage is going to be a process. SO many torn down projects and parts and stuff lol..
So I have again accepted this is not going to happen quickly as hard as I've tried lol,
Since it is going to be down awhile, I think I'm going to pick up a 30T crank sprocket from Evo Ind. and lets madness's guy size it up for my crank. That weight reduction is hard to get over lol. I will get an off set 19T final and run my current 41T rear. This is going to take quite a bit more time, but I think will be well worth it in the long run.
Old 8th March 2017
MatHormell's Avatar
well made minimal progress, but some is better than none! lol..
Got the rear wheel centered in the frame, ground down the wheel spacer that came with wheel to .655 which has the rear wheel placed right about center frame. Used a straight edge and used it to measure from the outside of rear drive sprocket to my current front drive sprocket, Offset came out to .758. So now I know how much to off set the front sprocket. Just need to find someone with a 19T 3/4" offset front drive sprocket.
Old 8th March 2017
Tom Beckner Tom Beckner is offline
Sportster/Buell Model: XLH 883/HP 1250
Tom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond reputeTom Beckner has a reputation beyond repute
Originally Posted by MatHormell View Post
...Used a straight edge and used it to measure from the outside of rear drive
Mat, what's the part number on your current front sprocket?
520 or 530 chain?
Tom Beckner
Old 8th March 2017
MatHormell's Avatar
520 or 530 chain?
Tom Beckner
277 pbi 520 but I'm going to go 530 this time around so need a 530 19t with 3/4 offset.. Reached out to DG chassis but they want about $275 for it after its all said and done! Yikes!
Old 8th March 2017
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud ofcycowrencher has much to be proud of
Pbi makes a .750 530. I beleive its the 281 series.
SuiCyco Racing
47L
In Honor of Charlie Roach RIP
USN 1991-1995 VFA-81/ USS Saratoga, Iraq 1, Kosovo/ Bosnia Conflict
Old 8th March 2017
MatHormell's Avatar
SuiCyco Racing
47L
Yea but only as small as a 21 I believe is what I saw., Looking for the 19T
