Last Post: rurlndum
0 WTB: Factory Ironhead 2-1 Head Pipes
Last Post: wrkdWS6
0 timing troubles!
Last Post: 72 Ironhead XLH
4 Grinding noise when revving up
Last Post: christophoro
Last Post: longride
0 Is this 1200R worth $4500?
14 DEAR Harley Davidson,
Last Post: awilson40
0 Winter Storm Warning
4 The no-debate OIL POLL
0 Celebrating Sportsterpedia's Third Anniversary
0 68 xlch wiring
Last Post: Zach68
0 joyride memories xlx ironhead
0 Does Synthetic Engine Oil cause Higher or Lower temps at the oil tank?
Last Post: Sportycus
0 Mustang's new seat? Anyone tried it?
0 Photos: King Peanut or Regular Peanut tank?
Last Post: Calcustom
0 XL883L 2006 coughing and backfiring
Last Post: Bama Lee XLC
0 How many helmets?
0 Clutch Spring plate poll
Last Post: bimbo
0 What oil temp do you run
Last Post: JKKO
Last Post: 1977iron
steve yorke (61), edman (53), Hudsonator (51), kozman32 (51), R3DN3X (49), gmcsid (48), mitch (43), Gotenfan (29)
90ci, big bore, engine builder, hammer performance, patriot defender
  #541
Old 9th August 2016
MatHormell's Avatar
MatHormell MatHormell is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: Buell XB12R
Other Motorcycle Model: Yamaha
MatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond repute
man I've been dying to get my bike back on the dyno to see what she's really putring down.. -I LUV XLF!--I LUV XLF!--I LUV XLF!--I LUV XLF!-ing dyno kept blowing fuses.. And fried our dynoware R/T eddy current brake driver.. 3rd time it's happened.. So. I rip the dyno apart.. Finally find the issue... The torque converter arm or what ever on the brake was shorted out.. So hopefully will get replacement parts by Thursday so I can rerun this biatch!! Anyways while I was in the dyno I merged my HP and TQ graphs.. Relooking at it.. This motor has way more power still in it.. Disregard the weird squiggles at the bottom.. Pick up tripped out at first..
Sent from my SAMSUNG-SM-G935A using Tapatalk
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HAMMER PERFORMANCE Intake Manifold
HSR 48 Miunki
XR1200 Crank Conversion W/ Case Mod 34T
HAMMER PERFORMANCE Sledge+ Head Work
2.020" Intake and 1.630" Exhaust Valves
Conical Valve Springs
S&S Premium Lifters
HAMMER PERFORMANCE Billet Push Rod Bases
Barnett Clutch Hub With Scorpion Clutch
Dynatek 2000i
R&D MOTORSPORTS- TRANSMISSION WORK-REM ISF
WorldWideBearings
Patriot Defender Exhaust
Old 9th August 2016
MatHormell's Avatar
Well that looks like shit.. Here's another
Old 9th August 2016
MatHormell's Avatar
Definitely was having a flat spot after 5500. Probably the jetting
Old 9th August 2016
TX Dreamer TX Dreamer is offline
TX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to allTX Dreamer is a name known to all
Those are some nice numbers!!!
Sent from my Nexus 6P using Tapatalk
Old 9th August 2016
MatHormell's Avatar
Yea they are very good, but not all she's capable of.. And with what's in this motor, it should be a bit higher.. Granted this run was all on the real rich side and it was shut down at 7k. I haven't actually tuned it yet, just safe for break in and WOT.. The needle range is pretty rich, I noticed that on the street with the innovative.. But haven't adjusted it until I get it back on the dyno.. Timing hasn't been messed with at all.. It's actually retarded a couple degrees, so I'm hoping after some real good fine tuning she'll be where she should be!
Old 9th August 2016
[quote name="TX Dreamer" post=5425952]Those are some nice numbers!!!<br />
<br />
Sent from my Nexus 6P using Tapatalk[/QUOTE]<br />
Yea they are very good, but not all she's capable of.. And with what's in this motor, it should be a bit higher.. Granted this run was all on the real rich side and it was shut down at 7k. I haven't actually tuned it yet, just safe for break in and WOT.. The needle range is pretty rich, I noticed that on the street with the innovative.. But haven't adjusted it until ingest back on the dyno.. Timing has been messed with at all.. It's actually retarded a couple degrees, so I'm hoping after some real good fine tuning she'll be where she should be! <br />
<br />
Where do you think your final numbers will be? 130ish HP and 110ish TQ?
Old 9th August 2016
MatHormell's Avatar
<br />
<br />
<br />
My inflated goal was 135/115 I think it will easily get 130/110 though
Old 9th August 2016
Would love to see this 1/4 mile times drop into the 10's. Abilene has an 1/8 mile track, not sure when they race though.
Old 9th August 2016
splineman's Avatar
splineman splineman is offline
Other Motorcycle Model: Honda GB400
Other Motorcycle Year: 1987
splineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond repute
130 hp.....nice!
Sent from my Nexus 5 using Tapatalk
Old 9th August 2016
MatHormell's Avatar
Yea I got a close 1/8 mile in Denton and another in Kemp tx.. May go to one and just. Work on 60s
