0 Significant exhaust pop at idle.
Last Post: firevf06
0 Cobra NH slipons
Last Post: Skeezix
0 clean spark plug
0 21 vs 22 vs 23 teeth sprocket
0 Carb fastening screw size?
0 05 carb rebuild no start
0 Accelerator nozzle and idle not right
Last Post: fafcpa
0 The salty debate thread.
0 Hello New in the Forum
0 93 883 Key switch and lighting
0 Starting bike after 6 year hiatus
Last Post: darwin-t
Last Post: bklyngeezer
0 Kick starter resistance
Last Post: jcro61
Last Post: XL Dane
0 Why Torx?
0 Small question about seats....
View Poll Results: Average riding, not 200 mls at 40 mph, what do you get?
20-40 mpg 279 17.50%
40-50 mpg 963 60.41%
50-60 mpg 324 20.33%
60+ mpg 28 1.76%
Voters: 1594. You may not vote on this poll
  #611
Old 13 Hours Ago
XL Dane XL Dane is offline
Sportster/Buell Model: Sportster 48, 1275 + 570
XL Dane is an unknown quantity at this point
I corrected the speedo a while ago, but I thought that the ECM knew the precise fuel consumption by using injector size and time?
Old 12 Hours Ago
But it needs to be calibrated, mine was way off as delivered. I corrected the speedo VSS first and then dealt with trip center. In "Trip Center" you enter correction factors. It was showing I'd used ~ 2.5 gal when I was putting in 3.0. I ended up with a 1.18 "fuel used" correction factor so what it shows for "fuel used" matches what I put in. I'd reset the trip meter then run 3 or 4 tanks of gas recording how much I put in, 10+ gal with my 4.5 gal tank, and would then apply a correction and check again and correct again. It took a while. Now it's dead on, it was worth doing.
It's handy runnin' down the road, being able to watch "trip econ (mpg)" and have a good idea how far I can stretch fuel stops.
Old 5 Hours Ago
Thumbs up
Ok thanks, good to know.
