14 I just kind of stumbled in here... like 100 times.
0 Info needed on mini sumps.
0 XR mutt race bike progress
Last Post: Scott
Last Post: BigLerowski
0 K/n air filter,, and s/s super b long thumb screw bolts
0 Ironhead high speed cruise prob
0 Coil readings
Last Post: Billy1200
Last Post: xElvis
0 Cleaning carbon build-up
Last Post: xElvis
0 Inherited Ironhead
Last Post: xElvis
Last Post: xElvis
0 Flame's New 1989
Last Post: webman94
0 Valve Lengths?
Last Post: motorhedmike
0 Transmission issues
0 Looking for an xlch engine
Last Post: Medyo Bastos
0 WTB: 1996 Sportster stock-ish exhaust and mid controls
Last Post: PRICHMON
0 Keihin Butterfly crack
Last Post: jasnoc
0 Cut Wiring, no spark.
0 Chinese S&S carbs
Last Post: 11B40
FORCE50 (68), marcus (55), gardkarlsen (50), dhoppe1 (42), Hagen (42), tdyer55 (38)
Old 6 Days Ago
keys79's Avatar
keys79 keys79 is offline
keys79 is an unknown quantity at this point
Default Problems relocating coil
Hey! new member and first post, but I've used this site as a resource for a while. I'm working on a 1995 Sportster that I picked up a couple months ago. Don't have it up and running yet but I'm getting close.
Anyway... I attempted to install a key & coil relocation bracket today and hit an unexpected speed bump. The stock wiring for the coil is not long enough. I can run it to the coil, but it pulls the whole wiring harness really tight, right across the open area above the front cylinder... which totally defeats the purpose of moving the coil.
Has anyone run across this? Do they make wiring extension kits? As an alternative, I'm willing to just cut the current wires and solder in longer ones, if anyone knows what kind of wire or gauge I need to use(?)
Also, since the coil is now flipped the spark plug wires are reversed, correct? Can you just flip the contacts on the bottom of the coil to fix that? Or is that just the way it is now?
Thanks!
Old 6 Days Ago
ohiodk ohiodk is online now
Sportster/Buell Model: xlh883
ohiodk is a splendid one to beholdohiodk is a splendid one to beholdohiodk is a splendid one to beholdohiodk is a splendid one to beholdohiodk is a splendid one to beholdohiodk is a splendid one to beholdohiodk is a splendid one to beholdohiodk is a splendid one to beholdohiodk is a splendid one to beholdohiodk is a splendid one to beholdohiodk is a splendid one to behold
Single fire or dual fire coil? Did you re route the coil wires? What kit did you get they are all a bit different and most come with the necessary instructions on using their product.
Just a guy with a couple bikes to cheap to pay a shop most of the time.
Old 6 Days Ago
keys79's Avatar
To be honest I don't know. It's the stock coil on a 1995 883, so whatever that would be. There isn't a way to reroute the wires because they are all bundled together. The wires for the coil exit the wiring bundle at a specific location that makes sense when the coil is mounted in the stock spot. But when you move the coil the wiring has to stretch pretty far.
And the relocation kit is really just a bracket that attaches between the cylinders on the left side of the bike. You use your existing coil and ignition, you just mount it to the new bracket.
Old 6 Days Ago
If it's the stock dual fire then both plugs fire at the same time so switching plug wires shouldn't be an issue from what I understand. I do believe the signal wires are 12 gauge if you want to extend them. At least on my bike they were but I dont have a stock harness. I would just extend them and take the time to hide them.
Old 6 Days Ago
ReddTigger's Avatar
You will need to extend the stock wiring, either by adding on an additional wire to the existing wire and using ring terminals, or by just cutting the stock wire and adding in a length of wire to reach the new location. i did it to mine about 10 years ago without problems.
States I've Ridden in
71.3 hp 70.8 tq
Old 6 Days Ago
keys79's Avatar
Ok, sounds like a plan. I just ordered some heat resistant 12 gauge wire, should be here tomorrow.
And ohiodk, when you say switching plug wires do you mean swapping the ring terminals on the bottom, or do you mean it doesn't matter which side of the coil the spark plug wires are connected to?
Old 6 Days Ago
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
It does not matter which plug is connected to which terminal on the coil. A dual fire coil (often referred to as a wasted spark coil) fires both plugs every time so it does not matter which is connected to which terminal.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 5 Days Ago
keys79's Avatar
Ok perfect, thanks! The wire should get here today so hopefully I'll have it buttoned up by the end of the week.
Old 2 Days Ago
sportsterdoc's Avatar
Using 12 gauge (typical house wire for 20 amp circuit) will not harm anything, but it is heavy and bulky to splice.
A 3.1 amp coil draws about 4 amps.
I like 16 gauge (12 amps) for most auto & M/C wiring for physical strength, but 18 gauge is fine. Probably only 20 gauge on newer bikes.
