6 Hello from Central Vermont
0 Age limit where belts should be replaced?
Last Post: frogg_nutts
0 Hello from Germany
Last Post: Clementine
5 Harley T-Shirts
0 Operation Live Wire
Last Post: WI_duker
0 Forum problems???
0 Need recommendations for 17"/18" Wheels (or maybe 19..)
Last Post: Edster
0 Hello from Murcia-SPAIN
Last Post: old dog
0 Trip to Rockies
Last Post: Blues
0 Magnetos
Last Post: Scott
0 Nothing much
Last Post: 83ironman
0 '06 Sporster Oil Tank drain
0 Oil Analysis?
0 electronic ignition
0 1979 XLH Carb
0 Piston size id?
0 Horseshoe Oil tanks repo China?
0 WTF Happened
0 How stock is your bike
hubbinator (70), sport53 (66), kship (54), jrmkel (40), IR88n3 (35), waltweezy45 (32), lumberjack (29)
  #561
Old 3rd August 2016
chris_b_owens's Avatar
chris_b_owens chris_b_owens is offline
Sportster/Buell Model: Sportster Iron 883
chris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud of
figured since I haven't posted in a while I would throw up some Instagram edits I have done recently.
Both bikes
Old 3rd August 2016
jabba the slut jabba the slut is offline
Sportster/Buell Model: 883 XL
jabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant futurejabba the slut has a brilliant future
sweet as, 2 top class machines
My '99 883 sporty build: http://xlforum.net/forums/showthread.php?t=1856943
Old 14th May 2017
b0fh's Avatar
b0fh b0fh is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: XL1200CX Roadster
Sportster/Buell Year #2: 2017
b0fh has much to be proud ofb0fh has much to be proud ofb0fh has much to be proud ofb0fh has much to be proud ofb0fh has much to be proud ofb0fh has much to be proud ofb0fh has much to be proud ofb0fh has much to be proud ofb0fh has much to be proud ofb0fh has much to be proud ofb0fh has much to be proud of
wow.
just got here by searching for info on the cafe seat. nice bike and story.
but for heavens sake dont rev this motor @ 8000rpm it still has an 883 stock crank inside. 6500 is plenty revs.
Old 20th October 2017
Nibelungen's Avatar
Bike Builder
very beautiful
congrats
it's worth now... is not possible to calculate...
either for the many parts bought or the many hours worked on her...
Phelan's Avatar
Phelan Phelan is offline
Sportster/Buell Model: EBR 1190 SX
Phelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud of
Originally Posted by b0fh View Post
wow.
nothing wrong with 8000 RPM on occassion after the motor work he's done. Lots of folks turning that RPM on stock XL cranks. XL883 and XL1200 use the same crank. Hammer has hit that on their dyno testing bike probably as many times as there are miles on the bike.
Love is the never-ending act of forgiveness - Peter Ustinov
Old 16th February 2018
Sorry for the really late reply. Thanks a lot.
wow.
Thanks for the compliments. When I did the motor work, I also sent the heads to Hammer Performance and had new valves and springs put in that support 8000 RPMs with no issues. That being said, I have the limiter set at 7500.
very beautiful
congrats
You are right, No way to calculate. I have a ton of money and time into it.
Here are a couple pics of a PCH trip.
