0 Iron brake light help
Last Post: Bryan83taco
0 Spectro STL 75W140
Last Post: Four Speed
0 Lacing a 21 inch wheel to a 19 inch hub
Last Post: Mad Max
Last Post: sportyone
0 Modified heads
0 79 Tranny
0 1200S cam comparisons
Last Post: Saint666
0 Valve adjustment question
5 Summer time heat
0 Drag Specialties Headlight Housing + LED?
Last Post: Eddie Lives On
0 Front cylinder noise
0 How do you upshift?
0 WTF Happened
Last Post: VaFish
0 Buell lightning
Last Post: Stickr
5 03 XlH1200 Best top end commination.
Last Post: Saint666
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 1981 ironhead xlh PROJECT
0 900 dual carb front head
Last Post: thefrenchowl
0 Hi from NY state
Wild One, Bugs (66), Blazer (63), OnDVirg (63), Buggyboy (60), TheChimp (45)
Old 30th August 2015
Sportster/Buell Year: 1991
That was my question. Looks awesome, does it perform?
John
XLXR's Avatar
XLXR XLXR is offline
Do you still have stock forks / springs etc? What tires are you using? I will need new tires soon and I don't think they make Avon Venom X tires any more. Steering damper is a good idea.
Despite excellent suspension on my 2006 Roadster, I have no confidence at speeds over 90 mph. The bike will do it, I won't, getting too old I guess.
chris_b_owens's Avatar
chris_b_owens chris_b_owens is offline
Sportster/Buell Model: Sportster Iron 883
chris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud ofchris_b_owens has much to be proud of
I have Progressive Springs in the forks and the tires are Avon RoadRiders AM26's.
As aggressively as I have changed this bikes performance, geometry and suspension believe it or not I have had nothing but positive results. My wife's 48 with basically stock suspension tends to wobble but the Café bike never has.
Over all I am really happy with the bike's performance. The upgrades to the motor, suspension and braking have all made nothing but positive impacts to the bike.
Here are some of the performance oriented upgrades I have made.
Suspension:
Burly Brand / Progressive Stiletto 15" Rear Shocks
Burly Brand / Progressive Front Fork Spring Inserts
Roland Sands Design Front Fork Preload Adjusters
DBI Steering Stabilizer
Braking:
14mm Bore Front Master Cylinder (from a XL1200R)
Performance Machine 6 Piston Front Caliper
Performance Machine 4 Piston Rear Caliper
Roland Sands Design 13" Front Brake Rotor
Roland Sands Design 11.5" Rear Brake Rotor
Engine:
Hammer Performance 1250 Kit
Hammer Performance Smash Level Head Porting on Stock 883 Heads
Competition Valve Job with upgrades valve springs and titanium Retainers
Hammer Performance Impact 560 Cams
Hammer Performance Pushrods
Energy One Extra Plate Clutch Kit
PowerVision with AutoTune Pro Kit
The combination of all of this has made this bike really perform well. I have not had the bike Dyno'd yet but will soon and will post results when I do. As far as riding at speed. I regularly get to 100 and it is smooth as silk. Maybe I have been lucky but it all works....So Far...
XLXR's Avatar
Are they good in the twisties?
They seem to be. I am no pro rider but have ridden since I was a kid. I push the bike pretty hard and I have not had any issues. But again I would not consider my self a knee dragger either.
madlim madlim is offline
madlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond reputemadlim has a reputation beyond repute
My impression (from what I've read that is) is you get a good grip but low milage from them. I think Avon Venom is replaced by Cobra by the way. I run Cobra up front and Avon 3D X-M on the rear, very pleased over all.
Old 20th April 2018
thecarpenter's Avatar
thecarpenter thecarpenter is offline
Sportster/Buell Model: xl883
Other Motorcycle Model: KTM 990 Adventure
Other Motorcycle Year: 2009
thecarpenter is a splendid one to beholdthecarpenter is a splendid one to beholdthecarpenter is a splendid one to beholdthecarpenter is a splendid one to beholdthecarpenter is a splendid one to beholdthecarpenter is a splendid one to beholdthecarpenter is a splendid one to beholdthecarpenter is a splendid one to beholdthecarpenter is a splendid one to beholdthecarpenter is a splendid one to beholdthecarpenter is a splendid one to behold
Hi Cris,
Wanted to revive this thread to get a long term review of your tensioner.
here is a pic of an aluminum wheel I used.
Craig
http://www.michiganmotorz.com/billet...h-p-10815.html
Old 1st May 2018
Nibelungen's Avatar
Bike Builder
That's really a beautiful special with important and expensive mods...
Congrats again
