0 who rides with a Flyscreen (or similar) AND an open face helmet?
0 Tools
0 New member
0 Burns Stainless custom exhaust
Last Post: rubine
0 Mac exhaust
0 6 speed
0 2012 883 miss that comes and goes
Last Post: tussuck
Last Post: oupa
Last Post: 83XLX
0 More oil return questions
Last Post: Scott
0 883 cc >> 1200 cc big bore conversion
Last Post: lovevoodoo
Last Post: HDCUSTMBUILD
0 Brake pedal adjustment on 09 Custom
7 Ironhead yes or no
0 forged pistons?
0 Sportsterpedia Progress
0 IH rearsets and giant stud
Last Post: dewjantim
0 1250 break in map for tc88a
0 TC88A EEPROM or FLASH
3 Shaky Dave Recovery
0 Getting Hammered
Last Post: Bryan83taco
0 Power outlet
Last Post: RDHenley
brake rivets, brakes, disc brakes
Old 10th June 2011
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
Here's the tool I got just for this purpose.
Eric
http://www.aircraftspruce.com/catalo...RapcoBrake.php
Old 10th June 2011
Ivan RoachCoach's Avatar
Banned
Default I install my rivets the dirty...
...old-fashioned way: I peen them in place using the fat end of a punch and a tack hammer.
It allows me to completely flatten out the open end of the rivet.
Once you do it this way, you'll be able to expertly repair a loose brake pad on the side of the road with only a screwdriver handle and a rock.
Old 10th June 2011
While you're cooking that roadkill 'possum with your new camping kit!!! Don't forget to carry some salt/pepper and spices.
Eric
Old 26th February 2014
doodah man's Avatar
hey all, i'm reviving this old thread to ask: has anyone ever used pop rivets to secure their pie slice pads? i'm having no luck with the little brass rivets that came with the pads. or, is it a bad idea and i should forget about it? any tips for doing the rivets. i bought a set of transfer punches to help with the job, but it just isn't working.
Robicycle's Avatar
Robicycle Robicycle is offline
Sportster/Buell Year: 1969
Robicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of light
Man, I have one of these calipers that I need to rebuild...
So, you cannot find new pads for these Pie slice (74-77) calipers?
tracbike's Avatar
tracbike tracbike is offline
Sportster/Buell Model #2: Sportster XLH
Other Motorcycle Model: Trac Dynamics / Razor,
tracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the roughtracbike is a jewel in the rough
Eric
Eric says it works
doodah man's Avatar
oh yeah, you can find new pads easy, but they're not like other brake pads that are already bonded to a metal backing. the lovely pie slicer pads have to be riveted to the individual parts. i am considering the machine screws like bustert mentions... just seems like aluminum pop rivets would be stronger than brass rivets that are supplied anyway.
simeli simeli is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 69
Other Motorcycle Model: Sportster
Other Motorcycle Year: 70
simeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud of
You can use stainless pop rivets, stronger than brass, stronger than aluminum, as strong as the steel rivets and they don't corrode or rust, and they are easy to put in.
doodah man's Avatar
would it also be advisable to use some adhesive in conjunction with the stainless pop rivets? or are the rivets enough by themselves?
hcrashster's Avatar
hcrashster hcrashster is offline
Sportster/Buell Model: XLH Spinegrinder
Sportster/Buell Model #2: XLCH Frankenstien
Sportster/Buell Year #2: 1976
Other Motorcycle Model: Triumph Groanyville
Other Motorcycle Year: 1972
hcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud ofhcrashster has much to be proud of
Probably not needed.
Unless, of course, you can source an adhesive that withstands a fair amount of heat and can be removed by your average home mechanic. Or more importantly, the brake lining and backer can be separated without destroying the backing plate or causing needless damage, once again removed by somebody that doesn't own a nuclear accelerator or a broken microwave oven.
Or however they do it at New Brakes Am Us.
I can't think of any product offhand, but that don't mean someone hasn't invented such a hellgoop somewhere. Besides, if such a product exists why use rivets at all?
Ordinarily he is insane, but he has his lucid moments when he is only stupid
