Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Intake and Exhaust > Paying Taxes
Paying Taxes Got questions, tips or advice???
0 Done for now (no really)
Last Post: Pagey
0 2007 LED Neutral etc display cluster/bar
0 New oil tank
0 It's Glamazon's Birthday!
Last Post: ronccc
0 Fall 2020 GBB - kind of....
0 SE.536 cams, who has a set sitting around
0 Cruising RPMs
0 One More Ohio Meet & Eat?
0 XLCH chainguard
Last Post: ricusa
0 Rare As Hens Teeth? (Stock Parts Secondhand)
3 Wtb, Wts, Wtt, Wtg (EFIs)
Last Post: toomuchstuff
0 Big bore Stroker problem
0 Oil leaking
0 Repainted my bike
Last Post: chilly
0 newbie
0 Gear Spacing Question
Marsikus's Avatar
Marsikus Marsikus is online now
Sportster/Buell Year: 2019
Other Motorcycle Model: Aprilia Pegaso 650i.e.
Marsikus has a brilliant futureMarsikus has a brilliant futureMarsikus has a brilliant futureMarsikus has a brilliant futureMarsikus has a brilliant futureMarsikus has a brilliant futureMarsikus has a brilliant futureMarsikus has a brilliant futureMarsikus has a brilliant futureMarsikus has a brilliant futureMarsikus has a brilliant future
I am surprised about they are installing conventional FP3. I thought dealer reflashes ECU with some their own proprietary computer.
motorfish's Avatar
motorfish motorfish is offline
Sportster/Buell Year: 2012
motorfish is an unknown quantity at this point
In Kuwait the dealership is not allowed to use SE tuner, the EPA has made that illegal for them to even import. I guess these rules are same in all GCC countries. There are a few good dynos for bikes though, none of them will consider tuning with FP3, Power Vision is the way to go.
As for the quotation you've got, that is not bad (compared to Kuwait).
$ 196 is what you'd get charged per hour for labor at the dealer over here.
With regards to filter oiling, each time you clean it... for street cars we recommend 5000 km, for off road as needed. Basically, when the filter gets dirty/discolored, spray some Simple Green on the outside, wait 15 minutes, rinse from inside out. If still dirty, repeat, then let dry, and apply LIGHT coating of filter oil on the outside.
That makes the dust stick to the outer wire mesh, rather than penetrate the gauze filter element.
motorfish's Avatar
Labor is rather inexpensive.
Well, I guess it is an hourly rate, installing an air cleaner and mufflers is a half an hour job anyway, the other half an hour is for plugging in FP3 and waiting for the VH map to download
Old 6 Days Ago
They can, but what the dealership can/will do flashing the ECU is very limited and won't do much in the part throttle area where you spend the most time. I'd definitely go with Powervision over a FP3.
Old 6 Days Ago
Marsikus's Avatar
Thank you for advice! Even if my thrift will keep me from upgrade, I think that idea to purchase only tuner is good.
I have very positive experience about re-jetting carb towards richer mixture on older bike. So little change, but so smooth and cooler engine run in results.
Old 6 Days Ago
XL1275 XL1275 is offline
XL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant future
The main reason you are correct to get the engine to run cooler with more fuel. But if the dealer does the work, they will probably maintain the AFR at the factory level. I would probably just wait out the warranty then get what you really want. $2000 isn't cheap for something that isn't really gaining a lot if they are just going to set it back to the lean settings.
I have $3k in mine including engine mods, pipes, and Thundermax. Though the labor was mine. I'm pretty sure getting work done in the UAE isn't cheap.
The RPMs you are running are not going to take advantage of any real HP mods. Most don't break away from the normal HD curve until above 4K. The Hammer Performance website is the best at describing the various set ups. Some of it is not accurate as the HP gain was overstated on certain combinations. Not that they were being dishonest but it was more like a perfect scenario that aligned and is not repeatable across the board.
