0 Round Air Cleaner Poll
Last Post: Eric Von Zipper
0 Helmets Please...
0 17’ Roadster fork maintain or upgrade?
Last Post: exklumationx
0 A surprising and nice experience
Last Post: XL Dane
Last Post: jsandidge
0 XL 1200CX Wheels on 2020 883 iron
0 Thanks for having me.
0 Ignition advice
Last Post: Rhode Warrior
0 Hammer 1250 kit with fp3
Last Post: XL Dane
Last Post: Nitro57xl
0 'Floppy' Forks ???
0 Stalling when given throttle - video
Last Post: Boogiemanjoe
0 Magneto insulating block removal
0 What’s the cost (Replace Clutch)
Last Post: bklyngeezer
Last Post: Billy1200
0 Bendix insulator block
8 Crankshaft Failure
Last Post: JunkyardDog
Last Post: canoli
0 Thread revival
Last Post: gusm2
0 Lengthen 49mm forks, Sportster 48 ?
Last Post: XL Dane
0 Hagerty Insurance
Last Post: ss396
0 '69 XLH wiring question
Last Post: Doc308
0 86 c I burning pistons
reinhard (65), randolph196 (64), dexter (63), Swamp Fox (63), drewsport (58), paintslinger16 (57), grumpy0868 (52), Prototype (40), Tustan (40), dustom_99 (37)
jsandidge's Avatar
jsandidge jsandidge is online now
Sportster/Buell Year: 1981
Other Motorcycle Model: Suzuki GS850GL
Other Motorcycle Year: 1982
jsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to all
Default Clutch springs
My bike currently has what looks to be a Kibblewhite single clutch spring. I'm not crazy about the amount of effort it takes to pull in my clutch lever. I understand the original setup was a bit more user friendly. Looking on e-bay, I'm not sure which ones to get. Some say heavy-duty, others not - but they appear to be the same. Anyone have a link to something they are happy with?
bobber58 bobber58 is offline
Senior Master Bike Builder
Sportster/Buell Model: XLH bobber
Sportster/Buell Year: 1964
Sportster/Buell Model #2: XLH
Other Motorcycle Model: 883 Iron
Other Motorcycle Year: 2010
bobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to all
I just run used stock springs in my stock engines. Work fine.
jsandidge's Avatar
I was wondering about that. There are some used sets on e-bay.
I will not use that heavy single spring setup.
2 reasons, too stiff, single spring.
Stock spring is two springs that are counter wound, so the twist when compressed is minimized.
BigMek's Avatar
BigMek BigMek is offline
Sportster/Buell Year: 1982
BigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud ofBigMek has much to be proud of
JP Cycles has V-Twin clutch springs for a reasonable price. I haven't had any problems with them, and the clutch pull isn't bad if the rest of the clutch system (cable, lever, ramps) is in good order.
