0 Wet sump
0 While waiting on the paint to dry-and we thought it was the ballcheck
Last Post: Darkseacret
0 How to start a 1967 Sportster XLCH
Last Post: JackPrice53
0 XB9 crank?
Last Post: Curbside
0 Jutland 05-31-16
Last Post: slcharger
0 Hello from Murcia-SPAIN
Last Post: jcro61
0 XR1200 belly pan on an XL?
Last Post: CT XR rider
0 POLL: Vance and Hines
Last Post: Bama Lee XLC
0 And so it begins......
Last Post: Texassporty06
0 Spokes or Mags
Last Post: Desertfox
Last Post: WI_duker
0 Spokes question
Last Post: Doc308
Last Post: Nayra
0 Fuel Pump Problems
6 Is Your SPORTSTER...
0 How stock is your bike
fhilliard (78), paulmo (74), Beloved (48), Mr. Cro (48), Chopper Duke (40), Danny3nose (38)
1250, hammer performance, problem, scuffed, sportster
Old 4th October 2017
ROCK_4ever ROCK_4ever is offline
Sportster/Buell Model: Sportster 1275
ROCK_4ever is an unknown quantity at this point
Thumbs down 1250 screwed up after 3k miles
First of all, hi everyone! Before this day I only readed this forum, so this is my first post. Sorry for bad English. This winter i ordered hammer 1250 kit for my sporty, and today, after 3000 miles on it, i decided to rip her up and look how things are going.
And things are bad. Can cath this scratches on fingernail
There is no up/down movement of rods, or excessive freeplay of wristpins, so I'm confused about how things can go so wrong in just 3k miles. Also I've been confused about ring positioning on rear cylinder (kit was preassembled), but Aaron said that rings can rotate while engine operation.
Before disassembly compression was good, there was no detonation (dyna 2ki curve 4, 195/45 jets and best russian pump gas - 98RON). There are also no signs of detonation on pistons tops. Plug color tells me that I'm running slightly rich, but not critical. Heat cycles and break in done properly, like describeg in hammer instructions.
This is my first post so can,t attach images.
I will appreciate any opinions or advices from you, guys.
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
I don't know much of anything, hopefully some of the more knowledgeable guys chime in. However, from most of the similar threads in the past that I've read, tuning is often the common theme.
Did you send the photos to Hammer? What did they say?
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
hexnut's Avatar
hexnut hexnut is offline
Sportster/Buell Model: Sportster Superlow 1250
Sportster/Buell Year: 2014
hexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond repute
I would say there is a tuning problem.
2014 Sportster Superlow, Hammer 1250, smash head work, 560 cams, S&S rockers and lifters. ported throttle body and intake,
Hammer crush air cleaner, Barnett clutch
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
Progressive suspension front & rear
There are no dedonation/preignition signs, and bike runs great. I dont think that is tuning problem. I'd sent this photos to hammer guys, and Aaron agreed that there are no signs of detonation or overheating. He guessed that maybe there was some kind of debris in the oil. However i,ve changed oil twice during this riding season, and drained oil loooks normal. Bike also runs great, there was no oil consumtion at all. So I was very surprised when I saw that.
What kind of wrong tuning can cause this?
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
What was your reason to tear it down after only 3k miles?
04/07 1275 BFH heads .590 cams S&S 1.725 rockers TC88A HSR-45 S&S ac LSR 2-1
Riding season in our country was ended, and i want to do some headwork. Also I've noticed that the engine began to work a bit louder last time.
rocketmangb's Avatar
Why did you take it apart ?
Noise ?
Smoke ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Piston Scuffing
This is a sure sign of overheating and/or insufficient clearance. When an engine runs hot, the pistons swell up reducing the clearance between the piston and cylinder. The cylinder bore can also distort from localized hot spots, further adding to the problem. If a piston gets hot enough, it will scuff the wall wiping material off the sides of the piston. Where this occurs will give you a clue as to the cause.
If overheating is involved, the scuffing will be primarily on the upper ring lands and on the sides near the wrist pins. There may also be oil carbon and lacquer burned onto the underside of the piston indicating it was unusually hot.
The presence of scuff marks on the lower skirt area would tend to indicate a lubrication problem rather than an overheating problem. Scuff marks on the edges or corners of the thrust sides of the piston would indicate bore distortion as the culprit. Scuffing on both thrust sides would indicate binding in the wrist pin.
Any time you find evidence of scuffing, therefore, it’s important to diagnose and correct the underlying cause to prevent a repeat failure.
If the engine was recently rebuilt, the scuffing problem may be due to insufficient assembly clearances. The only way to know is to measure the pistons and cylinders. Measure the pistons at the top, center and bottom of the skirt area in two directions (parallel to the wrist pin and perpendicular to the wrist pin) to see if the pistons are within the manufacturer’s specifications.
If the pistons are the correct size, then measure the cylinder bore at the top, middle and bottom, also in two directions (parallel to the crankshaft and perpendicular to the crankshaft). This will tell you how much taper is in the bores, and if bore distortion is a problem. By subtracting the piston dimensions from the bore dimensions, you can figure the piston-to-cylinder clearance. If the clearance is within specifications, the underlying problem is overheating.
is the piston top fuel or oil related carbon? fuel dilution/ wall wash off does not take long to do damage. what about the air inlet track that allows dirt to get in. what about torque distortion?
