0 Rubbermount shocks on a rigid mount?
0 Finding a new doctor...
0 Flat Tire
Last Post: denguy
0 1968 xlch
Last Post: denguy
0 Motorcycle Events
Last Post: rhartlin
0 Bendix / Zenith questions
Last Post: hawgford
5 What's Your Temp Today
Last Post: Kbetts
0 C&C Seat Decision
0 1200 kit coversion with 50k miles?
Last Post: Blue Scoot
0 Stock Straight Rate Fork Spring Weight on Rubbermount 1200C
0 Arbor press for crankshaft
0 So heres the plan
Last Post: Bryan1976
0 compression problems
Last Post: oupa
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Forum problems???
Last Post: bplinson
Last Post: moparnut72
10 What's your Personal Tech
0 ultima iggy,, static time vs dynamic time
0 Seized Oil Pump
0 Hello from Seattle
Last Post: racemoto
0 my build in my apartment
0 Rocker Lockers - Quiet Down Annoying Top End Ticking
1250, hammer performance, scrambler, xl883
Old 11th January 2018
Merch131ho Merch131ho is offline
Sportster/Buell Model: XL1000
Sportster/Buell Year: 1979
Other Motorcycle Model: Merch 131
Merch131ho is a splendid one to beholdMerch131ho is a splendid one to beholdMerch131ho is a splendid one to beholdMerch131ho is a splendid one to beholdMerch131ho is a splendid one to beholdMerch131ho is a splendid one to beholdMerch131ho is a splendid one to beholdMerch131ho is a splendid one to beholdMerch131ho is a splendid one to beholdMerch131ho is a splendid one to beholdMerch131ho is a splendid one to behold
Default XL883 / 1250 Scrambler Project
I was helping my mate with the final assembly of his XL883 Scrambler project. The engine has a 1250 big bore kit from Hammer Performance, the heads have bigger valves and have been gas flowed by a specialist here in the UK.
I found the bike for my mate Tim about 5 years ago, so its been a very long term project, and its evolved over the years. Tim owns a bike shop and Dyno, but its seems he's always too busy to work on his own bikes.
But finally he's at the point of putting the bike back together for the last time
The alloy swing arm is by Metchemex, while the rear shocks are recently released by K Tech, called Razerback. The front end is a mixture of one off billet yokes with GSXR K7 forks, which have been modified with KTech internals.
The fork uppers and many other parts have been ceramically coated.. not sure the exact product, but its impressively hard wearing. For example, the coated cylinder head bolts were unmarked having been torqued down.
Also the oil tank has been replaced with a one off tank in alloy, which sits between the down tubes low down in front of the engine.
It also has a hydraulic clutch conversion, and switchgear from a Honda VFR800.
I'll go back next week when it should be back on its wheels, and fingers crossed be running and put on the Dyno soon after.. Hopefully I'll be free that day so I can film the action..
Here are some pics from today..
Old 5th February 2018
On its wheels, the bodywork is off being painted at the moment..
lugster's Avatar
lugster lugster is offline
Sportster/Buell Model: xl883r
lugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond repute
Man that pic is way to big....
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
So, where does the oil go?
Old 6th February 2018
Jheitt's Avatar
Jheitt Jheitt is offline
Sportster/Buell Model: XL883c
Other Motorcycle Model: Honda rebel 300
Other Motorcycle Year: 2018
Jheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud ofJheitt has much to be proud of
That is sweet!
Sent from my SM-G950W using Tapatalk
The new alloy oil tank sits low down in front of the engine, between the frame rails.
Your right, didn't expect it to be so big, this better..
Old 9th February 2018
The bike originally had a number board with a small LED headlight set into it. But it didn't look quite right, so it was replaced with a conventional chrome headlight, along with a odd looking mount. This mount had to use the three mounting holes drilled and threaded into the top and bottom billet yokes.
It looks a lot better now its been blacked out using ceramic anodising, to match the rest of the bike.
Old 24th February 2018
Here's a quick video of the bike I made a couple of weeks ago..
https://youtu.be/JZh7TL4uQ84
Wolff Wolff is offline
Wolff is an unknown quantity at this point
Looks great! How did you solve the coil bracket? Was that a separate assembly or drilled holes in the existing bracket that holds the choke?
Thanks!
