7 Hello from Spain
Last Post: juandemor
0 Galled front piston
0 carb pop on acceleration from stop
0 Street tracker
Last Post: yoshi
Last Post: jammantoo
0 Battery cover popping open while riding??
Last Post: yoshi
0 Hydraulic conversion for wet clutch
0 Front brake combination not working well. Suggestions?
0 Real Sportsters don't eat Quiche
5 RF turn signal flashing way too fast...
Last Post: rg500
0 LOOKING FOR 1981 MILWAUKEE SE OWNERS
0 Oil and smoke everywhere
Last Post: brianbbs67
0 First Harley
Last Post: Kaptain
0 Turn signals light up when i rev engine
Last Post: toadstool
5 1979 Sportster XLS Problems
Last Post: Thoroy
0 79 Engine Rebuild
Last Post: Fridge
0 Why cafe a sportster?
Last Post: tigger
Last Post: tigger
0 The forum got talent
0 Security system
0 New Guy's '76 Ironhead Build/Chop
Last Post: speedfoos
0 Your Favorite Style
Last Post: tigger
Last Post: Cropduster
0 Diagnostic help (Pinging)
Last Post: BradX13
Phil R (75), powellsanmiguel (71), pasqualeddpas (63), maruman (61), gmhsc (60), roachhill (48), redi2ride (44), eliminator96 (38), Booncha57 (37), drewkimmel93 (25)
noise, ping, sportster
  #31
the se module is probably a left over component. when the ign module was installed, you have tdc on flywheel set and then you align the led with the index mark on the trigger attached to the mechanical adv. this set tdc for the module and as the rpm increases, the trigger is adv.
someone may have used the harness so as not to run new wire. i run plug and play with my ultima and the stock sys by tapping the harness. so if the ultima goes south (and it did) all i have to do is unplug it and plug in the stock. i made hot glue blanking plugs to protect the open plugs.
he needs to check wiring, if the harness was used and the se module was reconnected, there def could be conflict.
BradX13 BradX13 is offline
BradX13 is an unknown quantity at this point
Ok so I do have a VOES ON the bike and I have a mechanical advance behind the pickup. I tried adjusting the pickup and it didn't seem to make any difference on the timing. I took pics but can't get them from my phone
Can you confirm the VOES is connected to the Ignition Control Module (ICM - behind triangle cover)? What pin#?
Can you confirm the pickup in the nosecone is connected to the ICM?
Can you identify the wires that are connected between the pickup in the nosecone and the pin numbers on the connector to the ICM?
As already stated - if both the mechanical advance --AND-- ICM are functioning, they are compounding the advance - which isn't the right way to do things...
You really need to get to the bottom of this situation...
Host your pictures onto a photo hosting site (but NOT Photobucket)... Then copy the links from where the photos are stored and put those links here inside the [IMG][/IMG] tags...
2 Relax
Ok so I checked the sound more closely. It's being heard from the exhaust port. I pulled the pipe the gasket looked fine, no sign of leakage. Inside the port has a ton of carbon build-up including on the valve stem. I pulled the rocker cover and there is no play or sign of wear either. I unplugged the ICM and the bike still ran and still made the noise. I'm not sure if that means anything but figured I'd mention it.
well, the carbon can cause mechanical noise, cause pre-ignition if glowing and can mess with the cylinder loading if it is shrouding or impeding exh flow. if you have a contaminated charge, it can not burn correctly. so maybe you found it.
also of note is if the cyl is consuming oil, oil will reduce octane and therefore cause detonation.
I know it's been a bit been very busy. This past weekend I happened upon an airleak so I picked up a gasket set and will be tearing down the top end Thursday and hopefully have it finished by Friday to make it to bike week. I strongly believe the airleak is the pinging issue but we will see
Old 3 Days Ago
Update on the bike. After completely tearing down the top end I found I had slight piston movement. Upon further inspection the front rod had some up and down play so those 2 things were causing the noise. I got a quote for the lower end to be rebuilt for $2k all said and done
Old 11 Hours Ago
Xlh1200 https://imgur.com/gallery/GkIQp8a
