Last Post: Calcustom
0 Hello from Germany
Last Post: Clementine
6 Hello from Central Vermont
0 Age limit where belts should be replaced?
5 Harley T-Shirts
0 Operation Live Wire
Last Post: WI_duker
0 Forum problems???
0 Need recommendations for 17"/18" Wheels (or maybe 19..)
Last Post: Edster
0 Hello from Murcia-SPAIN
Last Post: old dog
0 Trip to Rockies
Last Post: Blues
0 Magnetos
Last Post: Scott
0 Nothing much
Last Post: 83ironman
0 '06 Sporster Oil Tank drain
0 Oil Analysis?
0 electronic ignition
0 1979 XLH Carb
0 Piston size id?
0 Horseshoe Oil tanks repo China?
0 WTF Happened
0 How stock is your bike
hubbinator (70), sport53 (66), kship (54), jrmkel (40), IR88n3 (35), waltweezy45 (32), lumberjack (29)
Old 31st March 2018
DirtyHarry68's Avatar
DirtyHarry68 DirtyHarry68 is offline
Sportster/Buell Model: 1968
DirtyHarry68 has disabled reputation
Default Help with my clutch please
New cable, adjusting as per DR DICK’s procedure. All good on handlebar end.
When I fit the centre screw it’s all too tight, I’m thinking the clutch might be locked up due to no action for 6 months? Might be missing something, but don’t want to risk damage the worm gear lever.
I think MXHD55U has a procedure for this with the motor running, but I can’t find it. Is there a way I can do this before re-fitting the pipes/kicker etc?
Thanks
Al
Old 31st March 2018
MXHD55U MXHD55U is offline
Sportster/Buell Year: 1969
MXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant future
So when you pull the lever it doesn't move? Or are you saying when running even with the lever pulled you have no clutch?
Old 31st March 2018
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Model #2: Xl 883n
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
It should work not running. As to the worm gear lever, the AM all bend eventually. Some real fast.
Like MX said, what exactly is the issue? Spring tension can cause this too.
Ok, now I'm revived
Old 31st March 2018
Default ‘68- Clutch locked up?
Sorry if unclear. Worm and cable move through full travel correctly, but when in contact with clutch rod the worm won’t push it.
The bike hasn’t been running in a while - I seem to remember the clutch plates can stick together, this was my guess as to what has happened.
Al
Old 31st March 2018
ChinCactus's Avatar
Mine used to set up on my 74 every winter. You could pull the clutch lever but the clutch would not disengage.
I would have to start it in neutral, get someone to push me down the street then bang it into gear. Once she was running I could pull the clutch a few times and it would free up.
Did it every spring.
Old 31st March 2018
doodah man's Avatar
If you’re running your clutch dry, there should be no plates sticking together, unless your clutch is now completely oil soaked. Or are you running wet/dry plates wet?? Clutch rods in the correct order? Any “homemade” replacement rods?
Old 31st March 2018
Yeah, I think I missed something so need to have another look later when I can get back in the garage.
Worked fine before, removed sprocket cover, fixed broken stop pin, replaced chewed up clutch cable.
No clutch rods removed.
Could be oil soaked from standing / sumping.
I guess even if they were stuck together the lever would still operate the clutch springs then? I’m just feeling too much resistance, as in the cable will stretch or the worm gear lever will deform if I pull much harder.
Al
Old 31st March 2018
I notice Donny Peterson has a different approach to adjusting the clutch, adjusting the release rod from the primary side.
Al
Old 31st March 2018
Where is that info located?
If you want to do something, you’ll find a way. If you don’t, you’ll find an excuse.
Old 31st March 2018
P641, will PM you.
Al
