7 It's Nibelungen's Birthday!
0 brake lever for master cylinder.
5 Jiffy Standing
Last Post: 83XLX
0 Modified heads
Last Post: cazz1000
5 Summer time heat
10 Good Day for a Putt !
0 thk u for knowledge
Last Post: cazz1000
0 My Second Sporty A 2012 Forty-Eight
Last Post: shawn2002
0 2017 Headlight in 1991?
0 Patriot Defender Specs W/Pictures !
Last Post: Kbetts
0 Iron brake light help
5 Eye Protection When Riding?
Last Post: Karnevil
0 little rock
0 "Baffled"
Last Post: atVMAX99
0 883N brake/signal problem
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 New acquisition
Last Post: owlsplace
5 03 XlH1200 Best top end commination.
0 Valves & Seals
0 Spectro STL 75W140
Last Post: Four Speed
0 tire time
Last Post: 2cvandy
Last Post: Rocker52
05sportyr, fgray (84), Petrolhead (59), hallj_p (56), HellRazur (52), Tony_Fats (46), cian (44), ecmchip (43), robert (42), mdennett99 (35)
Old 17th December 2006
Uncledaddy's Avatar
Uncledaddy Uncledaddy is offline
Uncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud ofUncledaddy has much to be proud of
Originally Posted by melcheld
- What are you planning that required you pull the motor?
A couple things.
1: I could not access the bottom of the backbone tube which terminates under the battery box, just above the rear engine mount. That will be the main wiring access point from the handlebars to the ICM/TSSM/Battery.
2: I'm relocating the regulator from between the downtubes to underneath the engine to eliminate the wiring going to that part of the bike. That bracket will get chopped.
- I had the broomstick on my bike for about 2 months. I got rid of it because it put my wrists at an angle that became painful after only a short time. They really make you contort you arm to reach the brake/clutch levers.
I had the harley angled drags on there for over a year and found that my hands naturally prefer a more straight angle by the way I was gripping those bars. As far as the controls go, I understand what you're saying and guess I'll just have to find out. Thanks for the warning though.
XLFREAK XLFREAK is offline
No Posts
XLFREAK is an unknown quantity at this point
Originally Posted by chrishajer
Weigh the frame and swingarm first. Then compare that to a 2003 or earlier. I think that's most of the weight.
--Chris
was gonna post more babble but im fearing that doing so may seem like im hijacking thread. so im not gonna post my babble
4banger 4banger is offline
4banger has disabled reputation
Way to go UD, looking forward to watching your progress.
:usmc: 06 1200R, 30t,stage1,412's,thunderheader & speedscreen.
Uncledaddy's Avatar
The blue tape represents the area where I will be chopping the rear fender. I'm going to cut the struts short first and then draw the cut-line for the fender. I'm ordering the Lepera Bare Bones tomorrow.
What are you going to do for a bike while your ride is down? Or will that be the motivation to get her done fast?
VETRAN's Avatar
VETRAN VETRAN is offline
Sportster/Buell Model: XL883L Chopper Blue, Baby
VETRAN has disabled reputation
Default Oh I thought this was...
...a poll!
I too would be interested in teardown photos!
:pgrflag: [FONT="Comic Sans MS"]SPORTSTER...by choice![/FONT]
Uncledaddy's Avatar
Originally Posted by lagerdrinker
got me thinking of the possibilities.
how about weighing parts. wheres the weight of our bikes come from? why so heavy? hey, its winter. dont think i have anything good to add this time of year
Bare frame + bare rear fender = 77lbs
Swingarm = 12lbs
Uncledaddy's Avatar
Uncledaddy's Avatar
I could borrow my wife's Suzuki... nah, I'll wait.
My motivation is that with the holidays coming up, I'll have time off of work and I'm also between semesters at school.
Moved On Moved On is offline
Looks great UD !!!
I'm probably going to have broomsticks in the spring too, at least thats what's on the roller today.
Gazza
