0 front wheel speedo box
Last Post: chaz
Last Post: JB in NC
0 Rocker shaft locks
Last Post: screndname
Last Post: Roaldl
0 79 carb question
Last Post: chaz
0 starter clicking
Last Post: chaz
0 Speedo cable hunt
0 .551 Cams in an EFI 1200
Last Post: boonoorong
0 1989 oil filter lines
0 speedo drive for 1979
Last Post: chaz
0 supply and demand
Last Post: spoon
Last Post: Kingrabbit
0 Rocker Lockers - Quiet Down Annoying Top End Ticking
Last Post: Brendenhrvy
0 Spray on water resistance
0 Kehin carb spray nozzle
oldsporty1 (73), paris15 (65), thesmithiz (65), pajimmyjoe (64), chuckam (60), steve w (54), le_strike (47), Rubicon (41), r3db3ard3d (35), rortiz76 (35)
bearing, drum, grooves, hub, ironhead
Old 27th September 2011
nerdofreak nerdofreak is offline
nerdofreak is an unknown quantity at this point
Default Drum Brake Hub Interior Scoring or Machining?
Hi guys! I have been reading your forums ever since I purchased my '71 basketcase. Can not say how helpful your posts have been especially the Electrical Checklist Sticky?
I am having new rims and spokes put on what might be the original drum hubs and as part of the process I thought new wheel bearings might be in order.
I got the old crunchy bearings out and found that on the interior of the hub there what look to be perhaps some machined grooves. I did not see these as a detail in the FSM so thought some pictures might help. Are these grooves normal? Is my hub damaged? I first thought is that one might fill this area with grease and the grooves would direct the grease to the bearings.
I would be glad to take any additional pictures if it would help.
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond reputeericfreeman has a reputation beyond repute
Don't think those grooves will affect anything since the bearings and seals fit on the smooth areas near the outside.
Eric
GarryBoots GarryBoots is offline
GarryBoots is an unknown quantity at this point
I would guess the bore that these groves in is just clearance. I bet the fellas from the factory bored the hub, and then they rapid travel back with the tool presure still on the boring bar
