Keep & Kill
Snippets
17th June 2016
Posts: 1 Sportster/Buell Model: 1200 custom Sportster/Buell Year: 2005
05 1200 won't run
Hey I have an 05 sporty 1200 custom. I just added 12" mini apes with the burly brand cables. I went to start it up and all it does is turn the motor over and sounds like it's close to firing but at the same time it doesn't. I would let it sit and then tried restarting it but I looked and saw that my negative terminal on my battery melted. I got a new battery charged it up and went to start and it's still doing the same thing. I checked all my connections and they are good. Trying to figure out what's wrong. It was running perfect before I switched everything over, any advice?
17th June 2016
XLF LIFEMEMBER Im retired
Posts: 14,409 Sportster/Buell Model: XL50 0596 Black Sportster/Buell Year: 2007 Other Motorcycle Model: E-Glide Other Motorcycle Year: 2003
Welcome to the XLForum.
Retrace the wiring looking for a short would be my first step.
17th June 2016
Posts: 14,141 Sportster/Buell Model: 1200S Sportster/Buell Year: 2002 Sportster/Buell Model #2: XLH883 Sportster/Buell Year #2: 2003 Other Motorcycle Model: Moto Guzzi V7-850 SE Other Motorcycle Year: 2023
The basics of what IXL2Relax posted are do you have spark, fuel and compression?
Based on compression OK, then here is the very short version:
Were plugs wet, when pulled, after trying to start? If not, check for fuel flow (does accelerator pump squirt?...if not (and pump diaphragm is intact), then check if -
a. petcock screen not clogged? Fuel tank cap venting?
b. petcock flowing (vacuum connected on the vacuum operated)?
c. fuel in bowl (open drain screw [N/A on 1200S] is quick way to check)?
d. if a-c are OK, then remove carb bowl and check float valve not restricted with debris
e. float level correct?
f. If unsure, does starter fluid get it going? If so, then it is a fuel/fuel mixture issue. If you have fuel, then move on to the next step.
With plugs out, plugs in high voltage boots, plug prongs grounded (typically to cylinder/head cooling fins), kick the motor or operate the starter. Check for strong bright blue spark. If none, or weak, then check -
a. voltage to coil primary
b. measure coil resistance
c. check high voltage plug wires (both ends)
d. check spark plug condition
e. check coil primary connection to points/ignition module/ICM (04-06)/ECM (07 up).
f. If EVERYTHING checks good, but still no spark, then it may be the ignition module.
17th June 2016
Good advice, although it may have only been the cable clamp loose on the battery terminal.
