0 Keihin carb…mixture screw
0 Ran out of gas.
Last Post: Sportster25
0 Hello from Cape Cod
0 New to Harleys
0 Turn signals won't work when cold
Last Post: Debute23
0 Major update forthcoming
0 Cafe' Image thread WTFN
Last Post: tigger
0 2013 XL883L Electrical Question
5 Not charging, new Reg w/weird readings
Last Post: spoon
0 Turned down by a Tattoo Artist
Last Post: Deimus
0 Does Yankee Engineuity still exist?
Last Post: ReddTigger
0 The adventure of bringing my Sporty from Italy to Denmark
0 Question about our school systems
Last Post: delcrossv
0 Cams for Alcohol (E85-E98)
0 Front end assembly questions
Last Post: Kit352
0 Tachometer wiring/speedo hookup
Last Post: BigMek
0 Vacume gauge questions
Last Post: Fivecats
0 Need a mechanic
Last Post: Big_Baazzoo
0 Nick in piston causing my head gasket leak?
Last Post: JB in NC
0 Mikuni carb tuning issue
0 Guide to Swingarm Bearing Replacement
Last Post: JB in NC
DaddyJay, cartoad2001 (74), Dirty Ernie (68), ncpickman (62), bri1200c (60), pquirk (57), GOTWA (54), gremlinsteve (54), lbowles2 (52), Guess (44), rnaway22es, blueandy88 (40), landon283 (35)
1200, performer, ripper, sportster
Old 2nd June 2022
Stray Cat Stray Cat is offline
Stray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of lightStray Cat is a glorious beacon of light
Default Performance Cams
What's up guys?
Can anyone give me any feedback on the Andrews N4 cam?
I can't decide if i want to run these or the Feuling .515.
I've had SE .515 series cams and they are the best I've had on my bike.
Blew out the front exhast cam because the dude that installed them didn't clearance the case. But that's another thread...
Back to the matter at hand. I'm leaning toward the Feuling .515, but just want some feedback on the Andrews N4 .490 cam.
Is there much difference if i go with the .490 as opposed to the .515?
Any response is appreciated.
Old 2nd June 2022
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Do you mean SE .551's?
Old 2nd June 2022
When i bought them i was told they were Series "15" SE cams.
The person i bought them from said they were .515.
So, I'm going with that.
My bike was a '96 Sportster, 883 converted to 1200.
since i blew it up i installed a factory 1200.
Old 2nd June 2022
Dazed & Confused
What letters / numbers are on the sides of the cam lobes?
Old 2nd June 2022
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
The SE "15" cams are marked 15-1, 15-2, 15-3, 15-4. They are the .497 lift cams, 4th and 5th down in this list:
They've been discontinued.
They were original equipment in a large number of tube frame Buell models.
Per a source at HD, they are literally the Andrews N4's, despite minor differences in their specs. The spec difference comes mainly from a slightly different rocker ratio assumption.
Consider the 505/515 grind to be a lower overlap version of the SE .497/N4. Because they have lower overlap, they fit a wider range of applications. For example, sometimes the N4 causes piston to valve contact when paired with stock 883 heads. That will never happen with the 505/515 grind due to the lower overlap.
Something you should be thinking about is the compression ratio of your motor, and the matching of the cams to it. A stock 1200 motor of the 91-03 generation only has a 9:1 compression ratio. That's pretty soft for the 46-48 degree IVC of the cams you're considering here. Expect a large drop in bottom end power as a result.
Click Here to Contact Me
Old 2nd June 2022
Thank you very much, that is the information I was hoping to get.
Decided I'll be going with the Feuling .515 cams.
