0 Keihin carb…mixture screw
0 Ran out of gas.
0 Hello from Cape Cod
0 New to Harleys
0 Turn signals won't work when cold
Last Post: Debute23
0 Major update forthcoming
0 Cafe' Image thread WTFN
Last Post: tigger
0 2013 XL883L Electrical Question
5 Not charging, new Reg w/weird readings
Last Post: spoon
0 Turned down by a Tattoo Artist
Last Post: Deimus
0 Does Yankee Engineuity still exist?
Last Post: ReddTigger
0 The adventure of bringing my Sporty from Italy to Denmark
0 Question about our school systems
Last Post: delcrossv
0 Cams for Alcohol (E85-E98)
0 Front end assembly questions
Last Post: Kit352
0 Tachometer wiring/speedo hookup
Last Post: BigMek
0 Vacume gauge questions
Last Post: Fivecats
0 Need a mechanic
Last Post: Big_Baazzoo
0 Nick in piston causing my head gasket leak?
Last Post: JB in NC
0 Mikuni carb tuning issue
0 Guide to Swingarm Bearing Replacement
Last Post: JB in NC
DaddyJay, cartoad2001 (74), Dirty Ernie (68), ncpickman (62), bri1200c (60), pquirk (57), GOTWA (54), gremlinsteve (54), lbowles2 (52), Guess (44), rnaway22es, blueandy88 (40), landon283 (35)
cam gear wrongly marked, p cam gear, wrong cam gear mark
Old 21st November 2022
XLXLXL XLXLXL is offline
Sportster/Buell Year: 1973
XLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant futureXLXLXL has a brilliant future
Unhappy Harley Davidson Sportster Ironhead 1973 XLCH - XLH - P Cam Gear Wrongly Marked
Harley Davidson Sportster Ironhead 1973 XLCH - XLH - P Cam Gear #3 Wrongly Marked.
Mine has this flaw from the factory, which made me really in the depressing moment. It is written in the Clymer, but wasn't clear which # of the gear.
So I posted here to make a comparison for those who have a similar items for cam gear #3 of P cams. Hope this helps.
Here is the video to help you understand this
the blue marker is aligned with top cam lobe
the white mark is the correct ones
https://youtube.com/shorts/42CyAinCWr0
Old 22nd November 2022
DDDDylan DDDDylan is offline
Sportster/Buell Model: XLS 1000
Sportster/Buell Year: 1979
Other Motorcycle Model: CB750
Other Motorcycle Year: 1995
DDDDylan has a brilliant futureDDDDylan has a brilliant futureDDDDylan has a brilliant futureDDDDylan has a brilliant futureDDDDylan has a brilliant futureDDDDylan has a brilliant futureDDDDylan has a brilliant futureDDDDylan has a brilliant futureDDDDylan has a brilliant futureDDDDylan has a brilliant futureDDDDylan has a brilliant future
You said it is written in the Clymer... I have Clymer M419 and I see on page 124 they mention some early 1980 models have incorrectly marked cams, I believe this is also in TSB M-757. Is this to what you are referring? I don't see anything mentioned about older models like your 1973.
yes, it is true
my 1974ch had twin marks.
Old 23rd November 2022
Talking
Yes, mine is Clymer M419, when I read that one for the 1980, I then suspicious to what I have in my 1973. Apparently, it is wrongly marked as well. Good for Clymer to update theirs.
yes, it is true
Now I'm getting suspicious to all cam gears on this one.
How did you determine that the marks were wrong?
If #4 cam is marked correctly its timing will be wrong because it is lined up with #3 that is marked wrong?
No, I think I've got that wrong. If the 2 marks on #3 are spaced the right amount to each other, the gear tooth relationship of #4 to #2 will be correct and #4 will be timed right, but the #3 lobe will be out of position.
actually, the machine ran but was wayyyyy off, no power or throttle response.
If I've got this figured right the #3 error retards the front cylinder intake valve timing roughly 90 crankshaft degrees. So if the P cam intake normally closes at 40° ABC, yours would stay open to about 130° ABC (or 50° before top dead center).
The front compression stroke would be almost over before the intake closed.
I'm curious. Did you ever do a compression test? It seems the late closing of the intake wouldn't give the piston on its way up a chance to compress much of the charge.
Old 24th November 2022
I just think simple, when the push rod doesn't go up and down like in order, we realize something wasn't correct. But initially we are thinking about pushrod is bent, etc etc. Until a friend came for help, offering stock cam gears that came off from proper running bike
exactly, it ran, but not nicely. The machine coughing, and after running several minutes 2k-4k rpms, machine start falling stalling...
yeah, you are right. we should have done the compression test in the beginning.
