0 Keihin carb…mixture screw
0 Ran out of gas.
0 Hello from Cape Cod
0 New to Harleys
0 Turn signals won't work when cold
Last Post: Debute23
0 Major update forthcoming
0 Cafe' Image thread WTFN
Last Post: tigger
0 2013 XL883L Electrical Question
5 Not charging, new Reg w/weird readings
Last Post: spoon
0 Turned down by a Tattoo Artist
Last Post: Deimus
0 Does Yankee Engineuity still exist?
Last Post: ReddTigger
0 The adventure of bringing my Sporty from Italy to Denmark
0 Question about our school systems
Last Post: delcrossv
0 Cams for Alcohol (E85-E98)
0 Front end assembly questions
Last Post: Kit352
0 Tachometer wiring/speedo hookup
Last Post: BigMek
0 Vacume gauge questions
Last Post: Fivecats
0 Need a mechanic
Last Post: Big_Baazzoo
0 Nick in piston causing my head gasket leak?
Last Post: JB in NC
0 Mikuni carb tuning issue
0 Guide to Swingarm Bearing Replacement
Last Post: JB in NC
DaddyJay, cartoad2001 (74), Dirty Ernie (68), ncpickman (62), bri1200c (60), pquirk (57), GOTWA (54), gremlinsteve (54), lbowles2 (52), Guess (44), rnaway22es, blueandy88 (40), landon283 (35)
280-300 rear tire, parts, swing arm, wide
Old 26th March 2023
Jtl2 Jtl2 is offline
Sportster/Buell Model: 883 hugger
Jtl2 is an unknown quantity at this point
Default I like big tires and I will not lie
Hey, I have a 2002 883 Hugger and am tryin to find parts to widen the rear tire to 280-300. Anyone have suggestions where to find custom swingarm, front and rear sprockets, spacers, etc? Wheels n tires too, I spose, tho I’ve seen a few. Also, how wide of a tire can I go on stock front wheel? Thanks in advance!
Old 26th March 2023
rejeanprimeau's Avatar
RSD,Zodiac, Carlson Mid West and ect offer wide swing arm with the proper front sprocket.
They all need to have some fab skill to be install; spacer and bracket.
Old 27th March 2023
I’ll take a look. Appreciate the help, thanks
Old 27th March 2023
Sportster/Buell Year #2: '03
you didn't mention a wider rim/s? never mind.
72 1000cc barrels and XLR heads, S&S 4-1/2'' flywheels, sifton minus-minus cams, S&S super A w/ zippers thunderjet w/yost powertube, Andrews gears,and shafts, 72 oil pump, Morris magneto w/auto advance and single fire module, cycle electric generator w/electronic regulator,73 cu.in.
Old 28th March 2023
Yes, wider rims too. Actually, can I put a 130
Tire on the stock front rim? It has a 100 now
