0 1983 Ironhead! No Spark
Last Post: God of Thunder
0 Keihin carb…mixture screw
0 Ran out of gas.
0 Hello from Cape Cod
0 New to Harleys
0 Turn signals won't work when cold
Last Post: Debute23
0 Major update forthcoming
0 Cafe' Image thread WTFN
Last Post: tigger
0 2013 XL883L Electrical Question
5 Not charging, new Reg w/weird readings
Last Post: spoon
0 Turned down by a Tattoo Artist
Last Post: Deimus
0 Does Yankee Engineuity still exist?
Last Post: ReddTigger
0 The adventure of bringing my Sporty from Italy to Denmark
0 Question about our school systems
Last Post: delcrossv
0 Cams for Alcohol (E85-E98)
0 Front end assembly questions
Last Post: Kit352
0 Tachometer wiring/speedo hookup
Last Post: BigMek
0 Vacume gauge questions
Last Post: Fivecats
0 Need a mechanic
Last Post: Big_Baazzoo
0 Nick in piston causing my head gasket leak?
Last Post: JB in NC
0 Mikuni carb tuning issue
0 Guide to Swingarm Bearing Replacement
Last Post: JB in NC
DaddyJay, cartoad2001 (74), Dirty Ernie (68), ncpickman (62), bri1200c (60), pquirk (57), GOTWA (54), gremlinsteve (54), lbowles2 (52), Guess (44), rnaway22es, blueandy88 (40), landon283 (35)
Old 26th May 2023
061275r 061275r is offline
061275r is an unknown quantity at this point
Default Jetting 42 mikuni
Got a hsr 42mm carb on an 06 883r converted with the basic 1275 hammer kit with 505/515 reaper cams and stock heads bike runs good but running a little lean I put the carb on right out of the box with no rejetting just tuned in with air fuel screw. Was wondering what jets to put me a little closer to where I should be. Live in berks county Pennsylvania. Thanks
Old 26th May 2023
1Scooter 1Scooter is offline
Sportster/Buell Model #2: 2004 XLH1200Custom
Other Motorcycle Model: 2007 FXDB
1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of
Ya should have read the set-up instructions. Here's what's in my Wife's 04 1200C: 17.5 idle jet, 165 main jet, needle middle notch, 50 pump jet, float hight 0.70. Mixture screw IN rich, OUT lean.
Old 26th May 2023
I read them just wanted someone else’s input if anyone else had a similar set up as mine since it didn’t come with a jet kit. I ordered the jets for it so I guess it’s time for some tuning. Your wife’s motor all stock besides the carb or?
Old 26th May 2023
Thanks for the input too
Old 26th May 2023
JB in NC JB in NC is offline
Sportster/Buell Year #2: 1993
Other Motorcycle Model: H-D FLH
Other Motorcycle Year: 1980
JB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond reputeJB in NC has a reputation beyond repute
With the Mikunis you have the luxury of just raising the jet needle, by moving its clip down a slot or two. No jets needed for that first step. Just take the top off the carb, reach in with a ball end Allen wrench, and loosen the clamp screw, and swing the clamp out of the way. Then pull the needle out with some (wait for it) ...needle-nosed pliers. Move the clip, and put the needle back in. That will richen the mixture through most of the operating range.
If you feel that it is lean off-idle, a change of the pilot jet is in order. These are available in 2.5 increments, so for instance if it has a 25 pilot jet, you could go up to 27.5, or 30 if the first change does not get it.
Main jet may well need no change; wide open testing after the other changes are made will tell you. Read your plugs for these tests. Or read your time slip for trap SPEED if testing at the strip.
Jim
Old 26th May 2023
Thanks jb I’m new to the mikunis read nothing but good things appreciate the input
Old 26th May 2023
sungod's Avatar
sungod sungod is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 1973
+1
Jim
Old 29th May 2023
wrkdWS6 wrkdWS6 is offline
Sportster/Buell Year: '06
Sportster/Buell Model #2: XLCH Drag Bike
Sportster/Buell Year #2: '63
Other Motorcycle Model: Street Bob
Other Motorcycle Year: ‘21
wrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond repute
One of the most reputable HD tuners out there (Dave Stoddart at JD’s Cycle) happens to be over in the Lehigh valley. 2-3 hrs on the dyno at $100/hr would get it spot on from a AFR and timing perspective. He did my 1275 bike with HSR42 and my 140 wheel Softail. Something to think about.
Old 29th May 2023
Sportster/Buell Year #2: '03
^^^ can you be more specfic with the location?i'm familiar with the lehigh valley but that will just get me close.
72 1000cc barrels and XLR heads, S&S 4-1/2'' flywheels, sifton minus-minus cams, S&S super A w/ zippers thunderjet w/yost powertube, Andrews gears,and shafts, 72 oil pump, Morris magneto w/auto advance and single fire module, cycle electric generator w/electronic regulator,73 cu.in.
Old 29th May 2023
Thanks for the info I’m gonna check him out for sure man.
