Last Post: JB in NC
0 Rocker shaft locks
Last Post: screndname
0 front wheel speedo box
Last Post: Roaldl
0 79 carb question
Last Post: chaz
0 starter clicking
Last Post: chaz
0 Speedo cable hunt
0 .551 Cams in an EFI 1200
Last Post: boonoorong
0 1989 oil filter lines
0 speedo drive for 1979
Last Post: chaz
0 supply and demand
Last Post: spoon
Last Post: Kingrabbit
0 Rocker Lockers - Quiet Down Annoying Top End Ticking
Last Post: Brendenhrvy
0 Spray on water resistance
0 Kehin carb spray nozzle
oldsporty1 (73), paris15 (65), thesmithiz (65), pajimmyjoe (64), chuckam (60), steve w (54), le_strike (47), Rubicon (41), r3db3ard3d (35), rortiz76 (35)
brake, drum, rear
Old 20th October 2010
pdamedic's Avatar
pdamedic pdamedic is offline
Sportster/Buell Model: 1000 XLH
Sportster/Buell Year: 1976
Sportster/Buell Model #2: 1000 XLH Project
Sportster/Buell Year #2: 1979
Other Motorcycle Year: 2008
pdamedic is an unknown quantity at this point
Default 76 Brake Drum Removal
I have looked all over for a thread on how to get the brake drum off on my 1976 rear wheel. Is it pressed on?
I was going to remove it to clean the wheel up while I have the back end apart.
Thanks
There are 8 small bolts, each with a tabbed lock washer, holding the brake shell onto the rear wheel.
pdamedic's Avatar
Yes I have them off the drum. I did not know if it is just stuck to the hub or it was pressed on. I did not want to beat on it if it is pressed on.
So you think a few whacks should knock it loose?
Originally Posted by pdamedic View Post
... So you think a few whacks should knock it loose?
Yes. I would use a regular hammer and a block of wood.
Sportster/Buell Year: 1971
Other Motorcycle Model: FXDL
I agree with Mick.
The drum is not a press on affair.
I think yours is just rusted in place to the flange of the hub.
Hammer and wood with a couple whacks should remove it.
pg
pdamedic's Avatar
Thanks guys....It took a large hammer and a about a dozen good wacks on the wood. It was rusted to the wheel hub.
