0 Modified heads
5 Summer time heat
10 Good Day for a Putt !
0 thk u for knowledge
Last Post: shawn2002
0 2017 Headlight in 1991?
0 Patriot Defender Specs W/Pictures !
Last Post: Kbetts
0 Iron brake light help
5 Eye Protection When Riding?
Last Post: Karnevil
0 little rock
0 "Baffled"
Last Post: atVMAX99
7 It's Nibelungen's Birthday!
0 883N brake/signal problem
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 New acquisition
Last Post: owlsplace
0 Valves & Seals
0 Spectro STL 75W140
Last Post: Four Speed
0 tire time
Last Post: 2cvandy
Last Post: Rocker52
0 Poll: How Tall are You?
Last Post: SLW210
05sportyr, fgray (84), Petrolhead (59), hallj_p (56), HellRazur (52), Tony_Fats (46), cian (44), ecmchip (43), robert (42), mdennett99 (35)
Old 6th November 2018
always check the last thing you changed.
lynnx lynnx is offline
lynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant futurelynnx has a brilliant future
I,m presuming that your bike is not magneto ignition?
If so, the stalling could well be caused by an electrical short sucking the power down the brake line!
I note you say you relocated the brake line - have you checked for battery terminal contact ?
If its a short I think anything else would have melted!!
I have an old car that stopped and caught fire at the same time because a 30amp cable (to the horns would you believe) shorted out ! Luckily fire was confined to the loom.
Sounds kinda similar.
Old 9th November 2018
Mad Max Mad Max is offline
Sportster/Buell Model: XLH 1000 Electric
Sportster/Buell Year: 1981
Mad Max is an unknown quantity at this point
The bike has no magneto.
I know the battery terminals are really close to the frame, maybe the cable was tangled after I installed the new battery....
I think I will use some sort of rubber on top of the terminals next time.
