Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Styles > Sportster Motorcycle Project
0 yost power tube guy
0 883 rev range
Last Post: Bigshankhank
Last Post: perfesser
0 passenger with driver's backrest
0 73 xlch gas flowing from carb
Last Post: toomanyhobbies
Last Post: BestCoastXL
0 oil filter stuck
0 S&S Super E
0 Iron 1966 XLRTT
Last Post: xlerate
0 Your Favorite Style
Last Post: AZbiker
Last Post: Marsikus
0 Chain drive vss
Last Post: jon1966uk
0 1983 Ironhead - Oil not Returning
0 Ia 83 xlx
0 Proper XLCH
0 Ironhead Exhaust Poll
0 Mukuni VM38 to Branch manifold boot
0 Old oil in motorcycle question
Last Post: denguy
0 Early model Sportster rear fenders. XLCH
Nightrider, jim wiseman (70), gone2dalake (68), bobzimm (65), JMan (54), csaintg (52), The Masshole (52), tinydawg (50), B.Curvin (50), eskiv (41), 05bluesportster (40), joka646 (37), Shoni (29)
  #211
Old 26th February 2021
Originally Posted by Ranchero50 View Post
Been using the bike as a bike whenever I could the past three years
Hey Jamie, Glad to see you posting again... And glad to hear you've been riding and not simply storing that bike...
Post some pics...
Explore The Sportsterpedia - An XLForum Information Resource!
Ranchero50's Avatar
Ranchero50 Ranchero50 is offline
Sportster/Buell Model: 1200 Street Brawler
Ranchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond reputeRanchero50 has a reputation beyond repute
Post some pics...
LOL, it literally looks exactly the same. I barely put two tanks through it last year thanks to a job change right before the Coof hit. I want to run it more this year to work but need a larger front sprocket as it's 10 minutes further and I don't like buzzing it above 4k on the interstate for too long.
For pics there's this, a '29 Ford model A based speedster the past two years. Hoping to get the body finished this summer. Then build a blown 4 banger powerplant and see if it'll make the commute down I-81 on occasion.
The build thread... http://xlforum.net/forums/showthread.php?t=1821880
That looks like an interesting project.
I’ll echo Kens comments about your return, and the newer project is awesome, please keep us posted, thanks.
I.B.A.#26543,
Old 5th March 2021
Ranchero50's Avatar
Lightbulb
Today's saga. Pics are clickable if you really want to.
Further with the fairing.
Spool gun for 14ga aluminum? They say you can't do this kinda stuff.
Really, really like the lines on this fairing.
And with the screen sorta in place. I have a new one coming from some Chinese guy on eBay. ETA ugknown...
And then this happened trying to get the sprocket nut off. Even looking at the manual I still managed to turn it the normal way to remove.
SMDH... All is not lost though.
Drilled a hole in the nut and eventually split it with a cold chisel.
Welded up with the spool gun.
Drilled a drill guide, 3/8" on one side and 5/16" for the tap hole one inch apart so it lands where the old one was.
Drilled and tapped, all better
All this for this, 30T replacing the 29T... Should be able to buzz down the interstate slightly below 4000rpm or slightly faster than before...
Waiting on a $10 nut. I just replaced the sprocket a couple years ago and can't believe that I forgot the LH nut. More to come...
Old 6th March 2021
Inspiring, thank you for sharing......
Old 8th March 2021
Ranchero50's Avatar
Lightbulb
So another partial weekend on the Sporty. Worked up some new gauge pods that will actually cages the gauges in the mounting plate. The old cups were glued in place and that didn't work out so well long term. Pictures are clickable for the full sized versions.
A chunk of scrap aluminum idler became the tubes.
Very lightweight now. Filled a trash can with aluminum spaghetti.
Elegance...
Rolled it outside for a look-see and am pretty happy with it. The fairing might be a shade to large looking for the bike but it's smaller than the commercial ones. The headlamp is also aimed down in the picture so the whole thing will flatten out once properly aimed. I do like the blue side covers. Bahama blue Duplicolor is pretty close from a distance.
More to come.
Old 8th March 2021
Elegance...
That is NICE WORK!
For Sportster Tech Info:
Old 8th March 2021
cal43's Avatar
cal43 cal43 is offline
looks great
Old 9th March 2021
Ranchero50's Avatar
Red face
That is NICE WORK!
Don't tell anyone but that purdy is covering up a mistake.
The little step on the edge of the cap is supposed to fit into the cup but I didn't have enough depth to clamp the plate (everything rattled) so I flipped it over, chucked the gauge and everything in the lathe and used my flap wheel grinder to radius the edge while it turned at slow speed. Cheaters sometimes win.
