0 compression problems
Last Post: swamp yankee
0 Hello from Murcia-SPAIN
0 Another 2 into 1 thread
Last Post: WI_duker
0 Late Ironhead cases interchangeability
0 Trackday Sportster
Last Post: Tag
0 1965 Ironhead in CT
Last Post: Scott
Last Post: oupa
Last Post: Tag
Last Post: oupa
0 Stock Straight Rate Fork Spring Weight on Rubbermount 1200C
Last Post: perfesser
0 It's Flame__'s Birthday!
Last Post: Maxdog2
Last Post: Edster
Last Post: gpydeski
Last Post: XL Ed
0 Front brake lever
0 A Separate Speedo and Tach
0 1968 xlch
6 Is Your SPORTSTER...
0 Clutch Adjustment Woes
0 85 clutch adjustment woes
0 Do you think is normal this fuel pump noise?
Last Post: Radheck
0 Sportster leaking fuel from small tube underneath bike.
0 Cold?
0 Spokes question
Last Post: Scott
0 Who's still riding???
5 What's Your Temp Today
cobra0478 (75), Han (62), priell3 (58), Byrdman (54), jsta (52), YaeDio (51), doc (45), jfunk (45), lenainrouge (44), JohnDao (40), Razer883 (33), Slapchop68 (25)
Old 25th November 2016
lmarshall73's Avatar
lmarshall73 lmarshall73 is offline
lmarshall73 is a name known to alllmarshall73 is a name known to alllmarshall73 is a name known to alllmarshall73 is a name known to alllmarshall73 is a name known to alllmarshall73 is a name known to alllmarshall73 is a name known to alllmarshall73 is a name known to alllmarshall73 is a name known to alllmarshall73 is a name known to alllmarshall73 is a name known to all
Default Third bike, first Harley
Picked up a 1996 XLH1200S on Wednesday:
Paid $2400. It has a few issues, but it was the cheapest 1200 in a 150 mile radius. For that price, I can handle a bike that needs a little work.
It has just over 29,400 miles and it runs strong. I'm guessing there has been some engine work done since the jugs and heads are black and the case is silver. It was a trade in at the shop I bought it from, so they didn't have any real history on it.
I can already tell it needs to have the fork seals done, it has a slight oil leak here:
The speedo & tach bracket is cracked, which appears to be a common issue, but an OEM replacement seems to be easy to come by from the MoCo.
I still need to go through it and check the plugs, hoses, change fluids, etc just to be sure everything is up to snuff. Otherwise, it mostly seems to need some cosmetic work (sheetmetal, seat, rust on the pipes, etc) but that is to be expected on a 20 year old bike.
And here's some pictures of my past projects:
2005 Suzuki C50 (my first bike):
1980 CB750:
sportsterdoc's Avatar
Welcome from southern Nevada.
Tom's Avatar
Tom Tom is offline
Sportster/Buell Model: 883R
Other Motorcycle Model: '84 FXE Super Glide
Tom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond reputeTom has a reputation beyond repute
Happy New Bike! I bought a '96 1200S new and they came with black highlighted heads and barrels with unpainted crankcases. That's not saying it hasn't had work done but a uncorked 1200 Sporty properly tuned is a strong runner.
Edit: just noticed your bike has a single disc front end, the early 1200S always had dual floating front discs with a floater in the back also.
That's good to know about the heads and jugs. Makes me feel a bit more comfortable. My plan is to ride this pretty much as-is until I get a Road King, then I'll probably put a 90" kit on the sporty. My roommate has an 883 Iron bumped up to 1200, but I want a bagger for when she wants to ride, but doesn't want to ride her own. Right now I've got a Street Glide sitting in the garage that a friend left here for the winter, so we've been taking that out every now and then.
halfmt1 halfmt1 is offline
Sportster/Buell Model: XL 1200s
Sportster/Buell Model #2: XR 1200x
Sportster/Buell Year #2: 2011
halfmt1 is a splendid one to beholdhalfmt1 is a splendid one to beholdhalfmt1 is a splendid one to beholdhalfmt1 is a splendid one to beholdhalfmt1 is a splendid one to beholdhalfmt1 is a splendid one to beholdhalfmt1 is a splendid one to beholdhalfmt1 is a splendid one to beholdhalfmt1 is a splendid one to beholdhalfmt1 is a splendid one to beholdhalfmt1 is a splendid one to behold
Are you sure that's an S model? Seems to be missing all of the S attributes, except the tank graphic.
When I entered the VIN for insurance, it came up as a 1200S.
What other attributes? I'm new to the world of earlier Sportsters.
shanneba shanneba is offline
Welcome to the forums from Indiana!
Maybe it is registered as a 1200S, check your VIN here-
The Sport was first to have
fully-adjustable front & rear suspension
dual front floating-disc brakes
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Came up as a 1200S
The forks have the adjusters. Piggyback shocks I can do without, but I really would like to have the dual disks up front...
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
A great single is a better choice. Less unsprung and rotating weight.
BUT the dual setup looks better.
I just checked, and it has a dual pot caliper on the left. I can live with that.
