10 Good Day for a Putt !
0 thk u for knowledge
Last Post: cazz1000
0 My Second Sporty A 2012 Forty-Eight
Last Post: shawn2002
0 2017 Headlight in 1991?
0 Patriot Defender Specs W/Pictures !
Last Post: Kbetts
0 Iron brake light help
0 Modified heads
Last Post: mikethebike61
5 Eye Protection When Riding?
Last Post: Karnevil
0 little rock
0 "Baffled"
Last Post: atVMAX99
7 It's Nibelungen's Birthday!
0 883N brake/signal problem
0 Bendix / Zenith questions
Last Post: DirtyHarry68
0 New acquisition
Last Post: owlsplace
5 03 XlH1200 Best top end commination.
0 Valves & Seals
0 Spectro STL 75W140
Last Post: Four Speed
0 tire time
Last Post: 2cvandy
5 Summer time heat
Last Post: Rocker52
0 Poll: How Tall are You?
Last Post: SLW210
05sportyr, fgray (84), Petrolhead (59), hallj_p (56), HellRazur (52), Tony_Fats (46), cian (44), ecmchip (43), robert (42), mdennett99 (35)
Old 25th June 2018
keithb's Avatar
keithb keithb is offline
keithb is an unknown quantity at this point
Default Bought a 2002 Custom 1200 - any must-fix issues?
Just picked up a 2002 Custom 1200cc with 4000 miles on it. Other than fluids, tires, fastener tightness, etc, are there any specific issues I should fix right away? Any time bombs waiting for me?
Old 25th June 2018
mikeLI_77's Avatar
It is not as big of a problem on your year bike as it is with the newer rubber mount bikes but getting rid of the spring plate in the clutch with an extra plate kit would not hurt. The rivets in the spring plate have a tendency to loosen up and sheer off eventually and can break the other parts in your primary when they let loose. That's about the biggest issue I can think of.
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
Old 26th June 2018
You might be interested in this thread:
Just Bought A Used Sportster - Checklists For Making It Right
And the Sportsterpedia section on the CV40 carb:
http://sportsterpedia.com/doku.php/techtalk:evo:carb02
You might also check the SP for sections on the VOES (vacuum lines) and about your nosecone ignition...
2 Relax
Old 26th June 2018
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
With only 4000 miles on it, I wouldn't worry about much. Ride and enjoy.
Old 26th June 2018
A 16-year-old locked in a closet for all that time may have some social issues... Just saying...
2 Relax
Old 26th June 2018
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
I would. I would worry about the rubber for sure. Check the date on your tires. If they are more than five years old, replace immediately.
Low mileage bikes are nice but, that low is not necessarily so. These bikes like to be ridden not, stored.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 26th June 2018
keithb's Avatar
Thanks everyone, tires are on my list of things to check, for sure!
Old 26th June 2018
Post no Avatars!
He already mentioned oil, tires and other stuff.
Other than that I would not worry about clutch plates or other things right now.
Old 26th June 2018
andy_t's Avatar
andy_t andy_t is offline
Sportster/Buell Year: 2016
andy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant future
Flush the brake fluid while you are at it?
Old 27th June 2018
"Rigids" often have taunt battery cables and can be more prone to vibration issures. Also, in that same thought the small Guage wires coming off the frame backbone, under the gastank, running to the coil can be fracture prone. I found that by pulling some extra length out and forming a small "s" into them cured that problem on my 2000"C".
