0 compression problems
Last Post: swamp yankee
0 Hello from Murcia-SPAIN
0 Another 2 into 1 thread
Last Post: WI_duker
0 Late Ironhead cases interchangeability
0 Trackday Sportster
Last Post: Tag
0 1965 Ironhead in CT
Last Post: Scott
Last Post: oupa
Last Post: Tag
Last Post: oupa
0 Stock Straight Rate Fork Spring Weight on Rubbermount 1200C
Last Post: perfesser
0 It's Flame__'s Birthday!
Last Post: Edster
Last Post: gpydeski
Last Post: XL Ed
0 Front brake lever
0 A Separate Speedo and Tach
0 1968 xlch
6 Is Your SPORTSTER...
0 Clutch Adjustment Woes
0 85 clutch adjustment woes
0 Do you think is normal this fuel pump noise?
Last Post: Radheck
0 Sportster leaking fuel from small tube underneath bike.
0 Cold?
0 Spokes question
Last Post: Scott
0 Who's still riding???
5 What's Your Temp Today
cobra0478 (75), Han (62), priell3 (58), Byrdman (54), jsta (52), YaeDio (51), doc (45), jfunk (45), lenainrouge (44), JohnDao (40), Razer883 (33), Slapchop68 (25)
Old 4th July 2018
BlackBikeDave's Avatar
BlackBikeDave BlackBikeDave is offline
BlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud ofBlackBikeDave has much to be proud of
Default Bent Forward Control Engine Mount
So when I had my accident, the right front forward control footrest bent and also bent the engine mount slightly. It moreso bent the top tab on the frame. I can see stress signs in the cracking paint where the bend is. When I screw in the new/used forward control footrest support you can see how its cocked up.
So a few things.
1. Is it ok to heat the tab and gently tap back into position.
2. Being that it's bent the engine mount is kinda wedged in..tho not badly. How do I get that off after undoing the bolts?
3. Is there any measurement the motor should be from each side of the frame? This way I know the motor wasn't shifted.
I was gonna give up but I'm slowly getting it back together. Need my knees in the breeze once again!
Jerome 'Kid' Campo - 2/27/13 RIP "and I Ride like the Wind..To Be Free Again"
Old 12th July 2018
jpeg would do nicely. heat may not be your friend as if not applied correctly, can make the metal brittle. if you decide to do so, go to a welding supply and get some temperature paint sticks so you can control the heat.
https://www.boconline.co.uk/en/image...410-113398.pdf
Old 12th July 2018
thank you, great info. I did see another thread here regarding the bent frame tabs. Mine aren't crazy bent but just enough to cock the footrest extension when I screw it in. I might be able to heat it enough to give it a couple love taps. Read to wrap wet rags around the frame near it as a heat sink.
Old 13th July 2018
Toejam503's Avatar
Subscribing Biker
Hey BlackBikeDave, if you're looking for measurements , the best place to get them is off another similar Sporty. Plus you can get the angles of the tabs, too.
Old 24th July 2018
So I ended up not putting any heat on it at all. I found a big pipe wrench that would fit in the space. Clamped it on the frame tab and gave it a gentle little twist and then another gentle bend strait. I don't think i stressed on them enough to damage them. Right Peg flys even again
