0 Tried starting the bike this morning, batter charged, but bike wont turnover?
Last Post: atVMAX99
0 Runs rough on highway.
0 Iron brake light help
Last Post: Bryan83taco
0 Spectro STL 75W140
Last Post: Four Speed
0 Lacing a 21 inch wheel to a 19 inch hub
Last Post: Mad Max
0 Modified heads
0 79 Tranny
0 1200S cam comparisons
Last Post: Saint666
0 Valve adjustment question
5 Summer time heat
0 Drag Specialties Headlight Housing + LED?
Last Post: Eddie Lives On
0 Front cylinder noise
0 How do you upshift?
0 WTF Happened
Last Post: VaFish
0 Buell lightning
Last Post: Stickr
5 03 XlH1200 Best top end commination.
Last Post: Saint666
0 Bendix / Zenith questions
Last Post: DirtyHarry68
Wild One, Bugs (66), Blazer (63), OnDVirg (63), Buggyboy (60), TheChimp (45)
Old 8th July 2018
senseigreen's Avatar
senseigreen senseigreen is offline
senseigreen is an unknown quantity at this point
Default rubber-mounted mids on rigid frame?
anyone know if the rubber-mounted evo mid controls will fit on an rigid frame evo? if so any heavy mods to do it?
ride em don't hide em
Old 8th July 2018
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
I shouldn't think so. Why would you want to?
Folkie
South East England Riders
Old 9th July 2018
BKB's Avatar
BKB BKB is offline
Short answer is no. The rubbermount peg brackets bolt directly to the bottom frame rails. Mid & forward. The rigid mount brackets mount to the front engine mount for the forwards. I don't remember where the mid mounts are attached on the rigids. No way you will get them to work without serious frame modification.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
Old 9th July 2018
thanks for the inputs, @folkie, i think the rubbermount mids looks like a cooler set up :b
Old 29th August 2018
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant futurefarmall has a brilliant future
It's easy to make mounting blocks for welding to the frame and you could weld the front, rear and bottom of each block without an engine pull by laying the bike on its side. That's how I did mine. I'll run a top pass on principle next time I pull the engine but have no worries about strength.
I've not done a Sporty but it's common for Twin Cam and bagger box FXR conversions, choppers etc.
I used a suitable chunk of steel (see your local metal supplier or machine shop for a scrap "cutoff") rectangle to give the standoff distance I wanted. I suggest choosing a block a couple inches longer than your desired final standoff distance so you've room to trim the frame side to fit.
Line up mid control mount on block, punch mark (transfer punches are best but not mandatory) through the bolt holes, then drill and tap for your mounting bolts. Bolt mid control mount to block, then fit block to frame.
All my cutting was done with cutting wheels on my 6" angle grinder (a much more versatile size than 4 1/2")
Look at the block with two bolt holes in this pic of a commercial kit:
https://www.fxrdivision.com/twin-cam...conversion-kit
I didn't bother grooving the tubing side of my mounting block since a couple of weld passes filled the gap nicely, but you can of course groove it with an angle grinder if you like. I prefer abrasive flap wheels to old style grinding wheels as they produce a smoother, polished cut.
Old 2nd September 2018
Sportster/Buell Year: 1991
The mid controls on my 1991 mount to the engine, not the frame.
John
Folkie's Avatar
Brass Nut
But the rubbermount mid pegs mount to the frame. If you want to mount them on a solidmount, they'll have to mount on the frame in the same way.
Old 6th September 2018
jkinkade jkinkade is offline
Sportster/Buell Model: XLH 88" 2003.
jkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant future
rubber mount motor, moves on rubber mounts. rigid motor stays same as frame.
so the mids on rigid can mount to motor but on rubber mount they need to mount to the frame. as would be moving around like the motor.
dyna are the same I had a dyna for 15 years. I can't see the point as would add weight.
2003 XL 88"
