5 Summer time heat
Last Post: Bob F
0 Valve adjustment question
Last Post: gpydeski
Last Post: CT XR rider
Last Post: Jarlaxle
0 Hi from Buffalo
Last Post: Phappus
0 lucas oil additive....
0 Spectro STL 75W140
Last Post: Four Speed
Last Post: frogg_nutts
0 Tried starting the bike this morning, batter charged, but bike wont turnover?
0 Runs rough on highway.
0 Modified heads
Last Post: wrkdWS6
0 Too HOT to ride?
Last Post: JaKaL
0 Hi from NY state
0 How to convert my dual disc '79 to a single 11.5" disc front end
Last Post: wrkdWS6
0 Engine stabilizers
Last Post: Gazotenekes
Last Post: gpydeski
0 900 dual carb front head
0 1981 ironhead xlh PROJECT
Last Post: roadsterboy
0 Do people notice your bike?
Last Post: brettxlch
5 Why Are You Still Married?
0 Oil Tank Cap doesn't fit right
0 New Photo Challenge: Show Us Your Bike Next to a Lighthouse!
mailmanjohn (52), 93customsporty (52), markmopar (52), ironheadTX (48), Austin-W (47), dcarterjr (47), MaX_01 (35)
Old 9th July 2018
conv90's Avatar
conv90 conv90 is offline
Sportster/Buell Year: 1990
Sportster/Buell Year #2: 1975
conv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant futureconv90 has a brilliant future
Default Oil cooler simple routing suggestion (see drawing)
I have a 4 speed with a 5 speed oil pump.
Due to different design the return line from the oil filter pad is not directly in to the pump but under the engine.
I have a little oil cooler ( a small metal tube with fins) with an IN and a OUT inlets.
where it's best to place it? Between A and B (feed line) or
between C and D (return) ?
1990 Sportster Axtell 90 ci, CP Carrillo 3.875 30° deg pistons,STD Heads, 615V2 RedShift cams, HSR48,
Carrillo 9.638 rods
Hammer Billet Sledge air filter
Hammer Billet Manifold.
160/60ZR17 rear on Akront 4.25" Alu rim
100/90-19 front on Akront 2.50" new Alu rim
YSS 13.75 rear shocks
1975 XLH almost stock
Old 11th July 2018
Lone Rider's Avatar
Sportster/Buell Model: 1200
I would think either would be fine as long as its not restricting oil flow.
Old 12th July 2018
conv90's Avatar
No restriction. It's basically a metal tube "U" shaped with fins.
Old 12th July 2018
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
Return line has higher pressure/flow - I'd put it there.
Old 13th July 2018
Do not agree. The return line has no restriction except from the bung on the tank. The scavenge pump also does not have to overcome the clearances in the oiling system. The pressure pump has to supply oil under pressure through those restrictions. The return line will carry oil heated by the engine operation though. So the oil temp in that line will be the hottest.
Joe
Old 13th July 2018
conv90's Avatar
So this can be good?
Old 13th July 2018
DEEP DIVER's Avatar
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
On my ironhead I have the cooler on the tank return line.
Old 13th July 2018
hbsporty's Avatar
hbsporty hbsporty is offline
Sportster/Buell Model: 883c>1250cc
Other Motorcycle Model: 2002 FLH Standard
hbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud of
Same on mine. Feed line from pump to cooler, other side of cooler to tank return.
Old 1st August 2018
conv90's Avatar
I have to admit that when at home after about 30 km in 40 mins in a 100°F day, the metal tubes of the cooler are cool. The first part of the hoses attached to it are cool too. The oil tank is hot . The oil temp is the same (195°F). But It's the hottest day I used the bike in this summer ..I never saw 100°F before in this summer.
Old 6th September 2018
WI_duker's Avatar
WI_duker WI_duker is offline
Sportster/Buell Year: 1988
Other Motorcycle Model: Blast
WI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond repute
I just bought a oil cooler.
The guy who did it to me fixes bikes.
He said put it on the oil return line to the tank
It's Hammer time
