0 compression problems
Last Post: swamp yankee
0 Hello from Murcia-SPAIN
0 Another 2 into 1 thread
Last Post: WI_duker
0 Late Ironhead cases interchangeability
0 Trackday Sportster
Last Post: Tag
0 1965 Ironhead in CT
Last Post: Scott
Last Post: oupa
Last Post: Tag
Last Post: oupa
0 Stock Straight Rate Fork Spring Weight on Rubbermount 1200C
Last Post: perfesser
0 It's Flame__'s Birthday!
Last Post: Edster
Last Post: gpydeski
Last Post: XL Ed
0 Front brake lever
0 A Separate Speedo and Tach
0 1968 xlch
6 Is Your SPORTSTER...
0 Clutch Adjustment Woes
0 85 clutch adjustment woes
0 Do you think is normal this fuel pump noise?
Last Post: Radheck
0 Sportster leaking fuel from small tube underneath bike.
0 Cold?
0 Spokes question
Last Post: Scott
0 Who's still riding???
5 What's Your Temp Today
cobra0478 (75), Han (62), priell3 (58), Byrdman (54), jsta (52), YaeDio (51), doc (45), jfunk (45), lenainrouge (44), JohnDao (40), Razer883 (33), Slapchop68 (25)
Old 19th July 2018
keithb's Avatar
keithb keithb is offline
keithb is an unknown quantity at this point
Default Am I missing a front wheel spacer?
2002 Sportster Custom
Recently had my tires replaced by a local independent mechanic with good reviews. Looking over the bike this morning, I'm wondering if I'm missing a front wheel spacer. The fork is mighty close to the wheel hub, MAYBE 1/16" clearance? Is there a spacer in there that I can't see, or is it missing?
Old 19th July 2018
jordan1200's Avatar
jordan1200 jordan1200 is offline
Sportster/Buell Model: 883/1200 Hugger Sportser
jordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant future
Try looking here.
http://partsfinder.onlinemicrofiche....FRONT%20(LACED)
Sent from my SM-G930W8 using Tapatalk
Jordan1200
1999 883 Hugger/1200 TS conversion,Buell domed pistons
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
Dynatek DC6-5 Single Fire Coul
SE 1340 air cleaner
Bassani Road Rage 2 into 1 Long Exhaust
Old 19th July 2018
keithb's Avatar
Thanks - the parts diagram does show a spacer, but I'm not sure if it's meant to be visible between the fork and the hub, or if it's recessed into the fork tube or hub.
Basically, I want confirmation that something is wrong before I go back to the mechanic.
Old 19th July 2018
Diogenes415's Avatar
Diogenes415 Diogenes415 is offline
Sportster/Buell Model #2: XL883C
Diogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond reputeDiogenes415 has a reputation beyond repute
it looks to me like you're missing a spacer and a dust seal.
**update**
If you can hold on about an hour I can get you a pic of the wheel and fork of my 2000 custom for reference.
Nope, it's a Sportster.
Old 19th July 2018
keithb's Avatar
**update**
That'd be awesome. Thanks!
Old 19th July 2018
I forgot how much the camera on my old phone sucks and why I use a real camera (which I didn't bring with me today). Let me try again after I get out of my next meeting.
Old 19th July 2018
keithb's Avatar
Thanks for the pic!
Hard to tell - IS there a spacer visible in there? How close is your fork tube to the hub?
Old 19th July 2018
Here's the Sportsterpedia section on Axles & Bearings:
http://sportsterpedia.com/doku.php/t...k:evo:wheels01
Check your year & model for Outer Bearing Spacers...
2000-2007 19“ Cast 13 Spoke or 19” / 21“ Laced or Profile Laced Front Wheel
Left:
43617-00A alum. - Width: 0.520“
Right:
43358-00 alum. w/ 3 'V' notches - Width: 0.140”
You could release the pinch bolt & make sure the forks a relaxed & straight (not pushed together out of alignment) - The axle mounts to the left fork solidly - the fork is then pinched to the axle head on the right...
2 Relax
Old 19th July 2018
Well this is as good as it's going to get given the crappy lens on my phone. It'll at least give you an idea of how much space there is between the hub and fork slider and the arrow is pointing right at the spacer that is sandwiched between the bearing and the step in the axle.
Old 19th July 2018
keithb's Avatar
Thanks everyone - I'll have to look a bit more closely, as it's not quite clear if something's missing or not.
