Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER S - REVOLUTION MAX > SPORTSTER S Motorcycle General Discussion and Problems
0 Transmission drain plug
Last Post: roadsterboy
0 1975 Sportster
Last Post: alsfarms
0 2003 Custom 1200
12 I caught a carburetor THISSSSSS rare
0 Clutch issue
Last Post: Fivecats
Last Post: SophieWillow
0 Indicators not flashing
0 Gear indicator missing
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Bikeaholic
Last Post: Animosity
Snuffy (72), cabby58 (63), SmoothyB (54), johnnyB (52), cayey (51), BIGschwerm (45), chief (45), Sporty Accorn (45), Muddypunk (36), Andreas (34)
Old 13th July 2021
shanneba shanneba is offline
Default Today is the day!
Sportster® S
Starts at $14,999.00
Sportster® S is the first chapter of a whole new book of the Sportster saga.
A legacy born in 1957 that outperformed the competition is now rebuilt to blow away the standards of today.
ENGINE TORQUE 94 ft-lb
ENGINE TORQUE (RPM) 6000
HORSEPOWER 121 HP / 90 kW @ 7500 rpm
FUEL CAPACITY
3.1 gal.
WEIGHT, IN RUNNING ORDER
502 lb
XHAUST
2-into-1-into-2; catalyst in muffler
FRONT FORK
43 mm inverted fork with compression, rebound and spring preload adjustability. Aluminum fork triple clamps.
REAR SHOCKS
Linkage-mounted, piggyback monoshock with compression, rebound and hydraulic spring preload adjustability
BRAKES, CALIPER TYPE
Front: radially mounted, monoblock, 4-piston caliper Rear: floating, single piston caliper
GAUGES
4 inch viewable area TFT display with speedometer, gear, odometer, fuel level, clock, trip, ambient temp, low temp alert, side stand down alert, TIP over alert, cruise, range
and tachometer indication BT capable - phone pairing to access phone calls, music, navigation (H-D App ONLY)
LIGHTS, INDICATOR LAMPS
All LED headlamp, low and high beam with signature position lighting. All LED Tail/Stop lamp with signature tail lighting
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 13th July 2021
I don't like it.
Old 13th July 2021
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
Us old guys don't like change. I don't.
The nature of life is change. So there.
A smaller exhaust would take some of the excessive mass away.
Steve
'01 Cyclone
'13 FXDC 96" stock
Old 13th July 2021
84rzv500r 84rzv500r is offline
Sportster/Buell Model: XLH 1200 S
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 83
Other Motorcycle Model: RZV500R/R1 hybrid
Other Motorcycle Year: 1984
84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute
Well im gonna do a Hammer 1275 and heads and I think ill give that one a run... its way more fun to build it and personalize it than buying it all done... IMHO
1999 XL 1200 Sport RX, SE 7500 ignition, SE air filter, DynoJet, K&N, Cone Engineering 2:1 pipe, Storz Steering damper, with 2012 XR1200X perf forks, 3.5 x18" wheels front and rear, Galfer stainless lines, XR1200 4 piston front calipers, 18" dunlop trailmax mission 120/90 and 140/80 rear XR1200X perf shocks with 1" lift blocks...
Old 13th July 2021
Steve9's Avatar
That's a good way to look at it.
I love my old air-cooled stuff. I lack good sense anyway.
Old 13th July 2021
XL Ed's Avatar
XL Ed XL Ed is offline
Have they posted any pics yet?
Old 13th July 2021
commando57 commando57 is offline
Sportster/Buell Year: 2016
Sportster/Buell Model #2: XL1200T
Sportster/Buell Year #2: 2017
Other Motorcycle Model: Z50A (Honda)
Other Motorcycle Year: 1969
commando57 is on a distinguished roadcommando57 is on a distinguished roadcommando57 is on a distinguished road
Why dont the big twins have trouble with emissions?
Old 13th July 2021
https://www.harley-davidson.com/us/e...ortster-s.html
Old 13th July 2021
NLXL's Avatar
NLXL NLXL is offline
Sportster/Buell Model: XL883DLX
It doesn't look like a Sportster
It doesn't sound like a Sportster
It probably won't ride like a Sportster
I'm afraid that for that kinda money people rather buy a 'real' Harley. There are two Softail models that are cheaper. I think this is gonna be the VROD story all over again. "VROD, The Sequel".
I stick to my old EVO.
Sportsterpedia
Old 13th July 2021
Sprtstr1200s's Avatar
Ok, lets see some specifics. 4 Valve, 6 speed, shop drawings, pass EU emissions. 1/4 mile times.
