0 Transmission drain plug
Last Post: roadsterboy
0 1975 Sportster
Last Post: alsfarms
0 2003 Custom 1200
12 I caught a carburetor THISSSSSS rare
0 Clutch issue
Last Post: Fivecats
Last Post: SophieWillow
0 Indicators not flashing
0 Gear indicator missing
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Bikeaholic
Last Post: Animosity
Snuffy (72), cabby58 (63), SmoothyB (54), johnnyB (52), cayey (51), BIGschwerm (45), chief (45), Sporty Accorn (45), Muddypunk (36), Andreas (34)
View Poll Results: Which Battery?
Harley Davidson OEM. 63 58.33%
After market stated in thread. 45 41.67%
Voters: 108. You may not vote on this poll
battery which best
  #81
Old 18th May 2021
Originally Posted by yelladox View Post
Is there any truth to Lithium batteries having issues charging in freezing or near-freezing temperatures? It's around that 5°C and less at least three months a year in DC.
Yes. Lead acid and LiFe batteries both put out less when cold but LiFe batteries take the bigger hit.
Doesn't start on the first try? Leave the ignition (and headlight) on so there's some drain on the battery which will warm the batteries' internals and bring its' output back up. Then hit it again. Not a big deal but something you need to be aware of with a LiFe battery.
Old 18th May 2021
yelladox yelladox is offline
Sportster/Buell Model: xl1200ns
Sportster/Buell Year: 2018
yelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant futureyelladox has a brilliant future
I guess my question is whether having it on a trickle charger will but futile in those temperatures: do I have to bring the battery in to charge it in warmer climate, or is it no problem having it sit in the bike, on a tender for a couple of weeks at a time?
Old 18th May 2021
...or is it no problem having it sit in the bike, on a tender for a couple of weeks at a time?
Leave it on a charger and you'll have no problem. LiFe batteries have a (very) low self discharge rate but the problem is the black drain the bike has because everything isn't really off when the ignition is off. HD has the dubious honor of being the industry leader in how much the the not really off system drains... Just use a good LiFe charger like an Optimate. I picked up and Optimate TM-291 and a TM-471 (2 because my R9T will also get a LiFe battery when its' battery dies) on e-bay very reasonably by being patient.
Old 8th June 2021
Bluto Bluto is offline
Other Motorcycle Year: 1973
Originally Posted by Bluto View Post
Been using a Yuasa GYZ16HL for nearly two years, 240 CCA vs. the 200 CCA of the stock battery and definitely starts with more vigor and less delay...
The battery above is still going strong however the terminal connections have loosened up three times now...and I've tried the standard fixes, star washers, thread locker etc. My guess is that the lead terminals get thinner from compression over time and that causes the loosening. (have had that experience wish tab washers on other bikes)
Anyway next time I'll go with a battery that does not require spacers or captive nuts...
Old 9th June 2021
Hellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant futureHellbent_4 has a brilliant future
I pull my battery in the fall so I get to experience reinstalling it every year.
Two years ago I had a horrible time with the terminals loosening - usually the hot, one time lost the negative bolt (speedo kept reseting).
I think the main problem was the cables vibrating and working the bolts loose.
I wound up forcing the cable against something then tightening it. That way the cable is braced against something solid and wont vibrate.
I've read somewhere on here about getting the more flexible cables can help.
Get one slightly longer to help installations, too.
Old 9th June 2021
Both of those may help, you might also think about running a small zip tie around the post cable and fastener. There are some pictures on site as well as in Sportsterpedia. Hope this helps you.
My 2000 was especially bad about it, actually the positive cable broke in half. I made up a new positive cable from some tinned multi stranded marine cable, heavier gage and a couple inches longer. Not been a problem these last 20 years.
I.B.A.#26543,
Old 25th July 2021
Fifty150's Avatar
Fifty150 Fifty150 is offline
Sportster/Buell Model: XL883L
Fifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant futureFifty150 has a brilliant future
I prefer the newer Lithium Batteries.
Lithium is better. More expensive to buy.
My bike came with the Harley Davidson 021-0123 battery charger. It's a Deltran Battery Tender with a Harley Label. I don't know if it will work with lithium batteries.
I bought a NOCO Genius 1. According to NOCO:
The GENIUS1 automatically detects sulfation/acid stratification. If any is found, the GENIUS1 will automatically repair and reverse the damage done to the battery, extending the usable life and increasing the performance. Genius will safely charge any battery. Detect damaged batteries and intuitively repair them. And actively monitor for long-term battery maintenance and extend battery life. This system allows for continuous operation without user intervention, and zero risk of overcharging your battery.
I don't think you can beat the Harley glass mat batteries. They just work and work and work. I've had them last 8 years.
My bike is an 05. It's now 2021. The OEM battery was probably made in 04, for an 05 model year bike. I've always parked the bike in my garage if I'm not going to ride it. Then the night before I intend to ride, I plug in the OEM charger. So for 17 years, the OEM battery has been on the bike.
Shopping for a lithium battery, got me to buying a lithium compatible charger. I bought the NOCO charger. And I bought the SAE connector. I had to try it. I plugged it in to the 17 year old battery. The next day, the bike fired right up with a 17 year old battery and a fresh charge.
Now I won't have to buy a lithium battery. That charger did whatever it was suppose to do with the battery. The 17 year old battery is just fine.
Old 25th July 2021
Andy56 Andy56 is offline
It will have the option to select it if it can. HD's new charger can do original AGM and new lithium.
Old 25th July 2021
rejeanprimeau's Avatar
I went with a ScreamPower from amazon, same supplier as Tesla and 520 CCA that fit in the same hole as OEM. I chose a SCR12BS scemower and boy that thing just crank the engine like your connected to the Hoover dam.
LiFePO type and it come with a tinny charger that work for this battery. The wiring just fit as OEM; left side positive when sitting on the bike. 131$ on amazon right now. Don't forget it come with a charger (cheap but made for it).
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
That's a good price. I love my anti-grav, but it is a bit more
Steve
'01 Cyclone
'13 FXDC 96" stock
