0 1982 rubber oil hoses
Last Post: Gravitas
Last Post: Bikeaholic
Last Post: Animosity
0 1975 Sportster
Last Post: Porkchop9
Last Post: SophieWillow
Last Post: 1Scooter
Last Post: jeffro57
0 Indicators not flashing
Last Post: steve-o-
0 1975 Sportster
Last Post: bplinson
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: jibber
0 Gear and brake linkage
Last Post: 93trident
0 1965 XLRTT article
Old 24th July 2021
mgentry66 mgentry66 is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 1983
Other Motorcycle Model: FLHTP
Other Motorcycle Year: 2009
mgentry66 has much to be proud ofmgentry66 has much to be proud ofmgentry66 has much to be proud ofmgentry66 has much to be proud ofmgentry66 has much to be proud ofmgentry66 has much to be proud ofmgentry66 has much to be proud ofmgentry66 has much to be proud ofmgentry66 has much to be proud ofmgentry66 has much to be proud ofmgentry66 has much to be proud of
Default Front Top Motor Mount
I have all the correct parts to install the missing front top motor mount on an 83XLX. Problem is, and prob why the PO did not re-install them, the rocker box bolts that are used to mount the motor mount are too long to slide in behind the neck with the motor still installed in the frame.
Is it possible / would there be enough wiggle room if I loosened the front cylinder.
Also, If I did this would the base gasket leak?
Otherwise it would seem as though I need to remove the heads to install this bolt and then put the heads back on.
anyone have any experience with this?
thanks
What I lack in experience I make up for in persistence even if just to spite you.
I will succeed
I blame society in the service of love
Old 24th July 2021
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud of
Looks like you'll need to pull the front rocker box so you can slip those bolts into place before re-fitting the rocker box.
Old 25th July 2021
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
Yeah, just the rocker box will do on the front head.
I wouldn't be too tempted to run without it. It is there for a reason.
Old 25th July 2021
ok, thanks guys. definitely a lot of work for two bolts. What must be done must be done.
thanks again
Old 25th July 2021
Blind Owl
You should probably stop now.
If your thinking this is a lot of work on an engine you probably don't want an Ironhead. These are lovely old pieces of machinery but require maintenance. Most of us on here enjoy working on them and look for opportunities to "play" with them.
If you just want to ride them youu would be better off with an Evo.
Or, perhaps a SUzuYamaHonda. (Do NOT consider a Ducati)
Old 25th July 2021
too late, rocker box removed. Now if I could get the damned paper gasket to free up from the mating surfaces. I do find it obsessively fun. I can'r seem to find enough time to satisfy my new obsession, wrenching on the IH. I was being a little more light hearted with my comment than you took me. It is a bit of work for two bolts, as some one else mention.
Old 25th July 2021
Blind Owl
Careful use of a box cutter and then some acetone to clean.
A small whetstone to finish off the surfaces.
Old 26th July 2021
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
It can be tedious...
1. Presoak with a spray can gasket remover.
2. Then use a hard backed razor blade, used carefully.
Repeat 1 & 2 a few to several times.
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Old 26th July 2021
ChinCactus's Avatar
ChinCactus ChinCactus is online now
Yeah, some things seem to be more tedious that you would thing they should be.
Sounds like you got this. Nothing like the satisfaction of keeping an old school, hands on bike!
