Last Post: nigeldavid
0 1982 rubber oil hoses
Last Post: Gravitas
Last Post: Bikeaholic
Last Post: Animosity
0 1975 Sportster
Last Post: Porkchop9
Last Post: SophieWillow
Last Post: 1Scooter
Last Post: jeffro57
0 Indicators not flashing
Last Post: steve-o-
0 1975 Sportster
Last Post: bplinson
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: jibber
0 Gear and brake linkage
Last Post: 93trident
0 1965 XLRTT article
  #41
Old 3rd August 2021
davixlrtt's Avatar
davixlrtt davixlrtt is offline
Sportster/Buell Model: 1965 xlch
Sportster/Buell Model #2: 1991 Honda XR600
Other Motorcycle Model: 1986 suzuki gsxr 750.
davixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant future
With a fresh battery an electric leg should be fast enough to get you a correct reading. Kicking is always "Problematical".
Kicking over is slow, put her into top gear and push for a few yards with the usual hot motor, wfo, choke off if you have one etc. (tape your plugs together if you have a magneto).
…….Davi.
Old 4th August 2021
kitabel kitabel is online now
Sportster/Buell Year: 1989
So many comments...
CCP is only close to static CR X atmospheric pressure by accident, there is no linear mathematical relationship.
VE at cranking speed is 100%.
The "dynamic" CR is based on cylinder volume at the intake valve closing point ABDC divided by the actual chamber volume (displacement of one cylinder divided by CR-1).
I've made a longer explanation on my site here: http://victorylibrary.com/tech/cam.htm
Old 4th August 2021
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
VE at cranking speed is 100 % ?
I would have to think carefully about that. Especially with very late closing intake cams.
To get 100% efficiency the valves would have to be fully closed at BDC.
At slower speeds some of the charge is going to be pushed back out of the combustion chamber.
The VE is going to change over engine RPMs as sometimes inertia of the incoming charge combines with a pressure wave happening at just the right time in the inlet tract to achieve effective VE higher than 100%.
At lower rpm's when the pressure waves are 180 degrees out it will work against you and reduce VE.
If you drop below the required VE the engine won't even start. You have to kick faster.
VE is only an approximated number. Static compression is an actual number but doesn't really tell you that much. And even with the best set up for checking cranking pressure it doesn't tell you the whole story as the pressure will rise in a running engine at high revs.
Of course, all of this is only my opinion and others may disagree.
Old 5th August 2021
Blair separates VE and captured charge very nicely.
Old 5th August 2021
Blind Owl
B2 × SE × .7854 (1 cylinder) [always less than “VN” , above]
The "VN" referred to is cylinder volume, nominal.
But I would disagree with that.
Tuned length exhausts and intake tracts are able to push VE above 100%.
On the intake side the combination of pressure waves and intake charge inertia will increase the internal pressure above what would be expected by normal atmospheric pressure. In effect, supercharging the cylinder.
Exhaust pressure waves timed correctly help lower the effective pressure in the pipe at the moment of valve opening and help in extracting the spent charges giving the intake a lower chamber pressure to fill.
This is exactly why we run open megaphones on single cylinder bikes along with what may seem overly long intake tracts.
And that's all great as long as you keep the engine in a very narrow rev range.
Again of course, this is only my opinion.
