Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > FORUM FUNCTIONS > Sportsterpedia.com Admin
Sportsterpedia.com Admin For discussion regarding the administration of the Sportster Wiki.
0 Indicators not flashing
Last Post: Gravitas
0 1982 rubber oil hoses
Last Post: nigeldavid
Last Post: Bikeaholic
Last Post: Animosity
0 1975 Sportster
Last Post: Porkchop9
Last Post: SophieWillow
Last Post: 1Scooter
Last Post: jeffro57
0 1975 Sportster
Last Post: bplinson
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: jibber
0 Gear and brake linkage
Last Post: 93trident
0 1965 XLRTT article
  #351
Old 18th July 2021
Sounds good to me.
I'll give it it's own section since we can't put all the pieces together.
The -02 rods may have only been for 2003.
I've found plenty of part numbers elsewhere that were actually fitted the following year after the beginning suffix.
Until we discover more, but yes, I agree they should be in the pedia.
This is the type information that belongs in the pedia actually.
Things you can't find anywhere else on the planet.
Old 18th July 2021
Got it changed.
Check it over to make sure everything is there.
It needs to right.
And thanks again for posting these. Learning something new everyday.
http://sportsterpedia.com/doku.php/t...01#section2003
Old 23rd July 2021
Graywolf Graywolf is offline
Good job, Y'all! You are dedicated and hard working. You have made finding information on the Sportsters much better organized and easier to find!
We would build a statue of you, the fathers of Sportsterpedia, but somebody would paint graffiti on it and tear it down.
Graywolf
Old 23rd July 2021
Thanks Graywolf.
I always said when I was younger that I was going to request to be reincarnated as a bird...…
But if they take all the statues down...… that limits me somewhat.
Old 25th July 2021
Thanks Graywolf.
You can still sit on car mirrors and leave white streaks down the doors.
Old 25th July 2021
See there, there is always a sunny side. You just gotta look for it.c
Old 26th July 2021
Just a quick note about the dash# & letter after the main part numbers - Hippysmack may have already addressed this somewhere
in the SP but I'll say it here anyway...
Dash numbers usually indicated the first year of use on SOME MODEL of HD - Not necessarily the first year on the Sportster,
even though it may now be used on a Sportster model. It might have originally been used on an FXR or even FLH model
when it was first assigned a number.
Upgraded dash# letters, like -00A or -00B or -00C, may indicate a succession of superceding parts, where the
highest lettered part# is retrofitted to earlier models that previously used a lower letter after the dash#.
BUT - It may also be that the later lettered parts are truly only compatible on a later model Sportster,
with the previous lettered dash# still available for earlier models (or obsoleted and not available at all even
though the new lettered part is not retrofittable).
The online version of the Parts Catalogs (for earlier model Sportsters) were often 2018 versions of those catalogs,
showing the most recent part#'s (and dash# letter) that are available for the part in question, listing it for previous
models where it was the retrofitted part now available.
I'll reiterate the fact that casting numbers are not the same as part numbers and we know for sure the same
casting number is used even when the boring or final machining is different for different models. Those will have
the same casting number, but different part numbers, or dash # or maybe only different lettered upgrade numbers.
Hippysmack already mentioned that some assemblies never listed the individual parts that were included. Sometimes,
in later model parts catalogs, they began listing some individual parts of those assemblies, but it's hard to say whether
those same parts were used on the previous assemblies where the individual parts were not identified.
And, he mentioned that the dash# may have been assigned at the end of a model year (like -02) as
a running upgrade but was never included in any parts catalogs for the 2002 models, but showed up
for the first time in the following year's parts catalog (ie., 2003).
This is what makes it tricky to describe the exact application of these dash# parts and
especially where there are multiple lettered upgrades.
Old 26th July 2021
Thanks for putting that all in one place.
I don't remember having a specific place for that but it may be a good addition to the Parts Catalog page?
I've collected parts books on a bunch of BTs but as soon as I go to something else, they have an updated catalog with updated parts lists.
My hope, once, was to be able to create a cross reference across HD models of parts that also fits Sportsters....
If I live that long that is.
But now we got newer parts with a bunch of numbers and no dash numbers.
Never run of something to do anyways.
Edit:
For the reasons IXL2Relax mentioned, you'll see original part numbers in the Sportsterpedia that you may not be able to find elsewhere as replacement parts.
Just as time goes by, OEM parts are obsoleted with updated parts by the MoCo.
Updated parts may be different colors or construction. And sometimes they are updated due to different vendors / suppliers / manufs the MoCo uses.
We are categorizing history as much as possible. This does not always coincide with what is available for sale at any given time.
We try our best to include updated parts as well.
But the pedia has gotten so huge, keeping part numbers current is difficult.
If anybody wants to send in an updated part# or list thereof, we'll include it.
Otherwise we'll update as we can.
Old 24th August 2021
I've rearranged the rigid tranny inspection page to be more expandable in the future.
1991-2003 5 Speed Transmission Removal / Inspection / Installation
Put it on the main page in the REF section and created sub docs for more in depth subjects to make things more digestible.
Still needs work but, one day at a time.
See also,
Setting 1991-2003 Shift Pawl Position
Why There is So Much Slop in the 1991-2003 Shifter Shaft
What Causes the 1991-2003 Shifter Detent Plate to Lean
What Causes the 1991-2003 Shift Drum Pins to Walk Out of the Drum
What Causes the 1991-2003 Shift Arm to Scrub the Starter Gear
1991-2003 Shifter Detent Plate Retaining Ring Alternatives
edit:
Forgot about these in the misc. resource section,
HD Part Numbers Explained
HD Casting Numbers, Letters and Symbols Explained
Old 25th August 2021
Nice, sir, and thank you again!
I.B.A.#26543,
