0 Q cams in 73 xlh ??
Last Post: Deimus
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Track Bike Build
Last Post: lehel
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Look at the plugs now. Are you shooting black smoke out of any pipe.
Sometimes it is that simple. Being Texan. Running like crumbs flies right over my head with nary a thought given to it.
still running like crumbs she wants to tick over lovley but she's still missing on rear cylinder was going well until she got warm then pop bang bang pop stutter pop bang turn key off walk away post on here
Edit: I usually solder the end of the braided cable to turn it more into a solid connection on the b carb wire connection screw hole.
http://xlforum.net/forums/showthread.php?t=1991650
Traveled to
