Last Post: mofosheee
Last Post: 73HEAD
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 HSR idle mixture screw
0 It's Glamazon's Birthday!
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
  #3351
Old 4 Weeks Ago
Tinz Tinz is offline
Sportster/Buell Model: X1
Tinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond reputeTinz has a reputation beyond repute
Originally Posted by cycowrencher View Post
Alrighty Gentlemen let's talk about the $2,400 four year lesson that I have learned with a 700 pound Sportster package. I've had this set up where I've had about 30 degrees of timing available from 3400 RPM all the way to redline at part throttle. What I needed was about 18 degrees of timing so my current timing curve under 5700 RPM is very lazy and at the 4k that I'm leaving at, we now have between 16 and 18 degrees of timing. The bike has 516 lb of spring in it and we have approximately 60 grams of weight on it and we're 60 footing in the 1.50 to 1.55 range. I highly recommend that if you are trying to calm it down on the hit, pull some timing.....
Sent from my LM-V405 using Tapatalk
Nice 60’ for sure, what ignition ya using? Data gathering?
Old 4 Weeks Ago
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond reputecycowrencher has a reputation beyond repute
Dynatec 2000i ignition and wego wideband with rpm data collect. Red line is rpm data green is afr
USN 1991-1995 VFA-81/ USS Saratoga, Iraq 1, Kosovo/ Bosnia Conflict
Old 4 Weeks Ago
I currently have 516 lb of spring and 56.8 grams across six arms.
Old 4 Weeks Ago
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
If I gotta run 500#’s of spring there’s going to be a bike for sale!
Old 4 Weeks Ago
jcro61 jcro61 is offline
Bike Builder
jcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud of
this isn't just a trend homie, it's a lifestyle...
Old 4 Weeks Ago
Are you running 7/8 bars? If so, the moose or fly racing easy pull 3 is the clutch perch and lever you want. I have the cable in the 2nd slot and that clutch feels like a +10 barnett diaphram... I had a custom cable made by barnett and it was 70ish shipped. The buell s3t cable will also work in a pinch...
Old 4 Weeks Ago
Currently my bike weighs 465lbs. I have 516lbs of spring in clutch.. Thats roughly bike wt+ (10% of bike wt)....
9 passes over 2 race days netted 60 fts 1.48- 1.55. Race e.t.s were 10.78- 10.82 with a random 10.687 yesterday when the air went from 1300ft to 700ft in an hour.....
Old 4 Weeks Ago
speedyrette speedyrette is offline
Sportster/Buell Model: Harley-Davidson Sportster
Sportster/Buell Year: 2014
speedyrette is an unknown quantity at this point
Six hour road trip to the last event of the year, rain delay today, full day tomorrow!
How did it go?
Old 4 Weeks Ago
Seems you have your combo sorted out, nice numbers.
Old 4 Weeks Ago
Originally Posted by speedyrette View Post
How did it go?
Out in the first round because I was in the right lane and can’t turn my head left enough to see where my competitor is…he was far back, went 11.35 on a 11.45 dial in. Breakout.
