Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > FORUM FUNCTIONS > Sportsterpedia.com Admin
Sportsterpedia.com Admin For discussion regarding the administration of the Sportster Wiki.
0 Clutch issue
0 1975 Sportster
0 1975 Sportster
0 Transmission drain plug
Last Post: roadsterboy
0 2003 Custom 1200
Last Post: SophieWillow
0 Indicators not flashing
0 Gear indicator missing
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
Last Post: Bikeaholic
Last Post: Animosity
Last Post: 84rzv500r
Snuffy (72), cabby58 (63), SmoothyB (54), johnnyB (52), cayey (51), BIGschwerm (45), chief (45), Sporty Accorn (45), Muddypunk (36), Andreas (34)
  #331
Old 16th June 2021
Over the past year, I've added and updated information in the Aftermarket Ignition Control Module page of the REFerence Section:
http://sportsterpedia.com/doku.php/t..._-_aftermarket
Today, I added the info on the Dynatek DSPT-1 ICM.
Old 23rd June 2021
Over the months, various threads & discussions have prompted me to update or add information to the Sportsterpedia. As discussions highlight the kind of questions people have or the misunderstandings of various operations, it encourages me to do the research needed to explain in better detail what people need for maintaining their rides.
I've been updating and adding information to the Keihin CV40 carb page:
http://sportsterpedia.com/doku.php/techtalk:evo:carb02
This has become a very long page but includes much critical information related to the operation and tuning of this carb.
I've added information about Throttle Chops (for evaluating the proper AFR at different engine operating conditions) & information on evaluating spark plug heat ranges:
http://sportsterpedia.com/doku.php/t...l_tuning_notes
A big THANK YOU to Wedge for giving me a good explanation of these functions as a basis for these updates.
A reminder here: You can save Sportsterpedia pages as PDF files. Use the 'Export: PDF' tab at the top of any page to output that entire page as a booklet with a Table of Contents and Index included.
Printout the PDF file for a ready reference while working on the bike.
Old 15th July 2021
Hippysmack's Avatar
I need to give an update also, but I can't remember where I've been since my last update.
I reworked and added to the Ironhead motor mount page.
http://www.sportsterpedia.com/doku.p...k:ih:engmech09
Added pinion gear pics and information to both the IH and Evo Camm pages;
IH Cam page
http://www.sportsterpedia.com/doku.p...02#pinion_gear
Evo Cam page
Moved the IH gauges to a sub document off the IH: Engine Control page and added pics and info to that page:
http://www.sportsterpedia.com/doku.p...talk:ih:elec03
New IH gauges page with added pics and info:
http://www.sportsterpedia.com/doku.p...alk:ih:elec03f
Broke the Evo rocker box maintenance page into several sub docs all linked from the main rocker box page:
http://www.sportsterpedia.com/doku.p...:evo:engmech04
Moved "Replacing Rocker Arm Bushings" to it's own page off the main tech page.
(still linked off the rocker box maintenance page as well)
http://www.sportsterpedia.com/doku.p...:ref:svcproc17
Both IXL2Relax and myself have been inserting information in various pages.
One reason I can't remember all the edits.
I'm currently creating a parts list with casting numbers for Evo rocker boxes.
It's starting to look like there were only a few changes to the boxes other than many part numbers for different colors/textures on the outside.
Running casting numbers were repeatable even though the part numbers changed.
Some changes also occurred without part or casting number changes.
But that chart is still in progress.
Old 16th July 2021
Thank you gentleman, much appreciated!
I.B.A.#26543,
Old 16th July 2021
Randy_rots Randy_rots is offline
Sportster/Buell Model: XL 1200 softail frame&NOS
Sportster/Buell Model #2: Buell XB1250 Uly XT
Randy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant future
In a crankshaft section, I don't see anything about 2003 crank that has different connrods 24225-02 24224-02.
I sold this crank few days ago but I still have photos of it.
Old 16th July 2021
If you create a thread with the pics, or post them here, we'll pick them up for inclusion.
Thanks for offering.
For Sportster Tech Info:
Old 17th July 2021
There you go 2003 883R crank
Old 17th July 2021
Hippysmack's Avatar
Thank you Randy. I'll get these added shortly.
I took mine apart for pics and stuff but at the time, I hadn't found a lot of stock pics.
So these will definitely be a welcomed addition.
Old 17th July 2021
I'm glad I could participate to Sportsterpedia a little
The photos of the connrods separated are salvaged from ebay auction but the photos of the complete crank are mine.
Regards
Old 17th July 2021
Hippysmack's Avatar
I've added those assembly pics to the pedia plus a little more information.
There is still much to be added though.
http://sportsterpedia.com/doku.php/t...01#section0003
Thank you very much for the pics.
Are the separate rods pics on an auction I can access, either open or closed?
If so I can contact the seller for permission to use them.
