Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > FORUM FUNCTIONS > Sportsterpedia.com Admin
Sportsterpedia.com Admin For discussion regarding the administration of the Sportster Wiki.
0 Transmission drain plug
Last Post: roadsterboy
0 1975 Sportster
Last Post: alsfarms
0 2003 Custom 1200
0 Clutch issue
Last Post: Fivecats
Last Post: SophieWillow
0 Indicators not flashing
0 Gear indicator missing
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Bikeaholic
Last Post: Animosity
Last Post: 84rzv500r
Snuffy (72), cabby58 (63), SmoothyB (54), johnnyB (52), cayey (51), BIGschwerm (45), chief (45), Sporty Accorn (45), Muddypunk (36), Andreas (34)
  #341
Old 17th July 2021
Randy_rots Randy_rots is offline
Sportster/Buell Model: XL 1200 softail frame&NOS
Sportster/Buell Model #2: Buell XB1250 Uly XT
Randy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant futureRandy_rots has a brilliant future
I've added those assembly pics to the pedia plus a little more information.
There is still much to be added though.
http://sportsterpedia.com/doku.php/t...01#section0003
Thank you very much for the pics.
Are the separate rods pics on an auction I can access, either open or closed?
If so I can contact the seller for permission to use them.
https://www.ebay.co.uk/itm/284299906...6a42%7Ciid%3A1
Old 17th July 2021
Also I think that this crank has revision "A" at the end of part number
Old 17th July 2021
Hippysmack's Avatar
The crank assembly being -A or flywheel casting numbers?
I couldn't see any wheel casting numbers in your pics but I want to make sure the information is correct.
We have 1 picture of the newer crank assembly 23905-00A upgrade from XLF member, Wilbur, from this thread.
http://xlforum.net/forums/showthread.php?t=657090
The seller for those rods has agreed for us to use his pics so I get them posted shortly.
edit:
I checked the parts books and flywheel assembly (23905-00) is the original assembly per the -03 catalog.
The -03B catalog shows flywheel assembly (23905-00A).
So the -00A wheel assembly is the replacement assembly for the -00 assembly.
Here is his old assembly which looks like yours.
Originally Posted by wilbur View Post
For comparison; here are the wheels I pulled out of the '03 rigid:
They are designed differently.
Old 17th July 2021
I have checked this web to get the part number for my 2003 flywheels:
https://www.jerseyh-d.com/original-h...ster&part=1385
I could be wrong but there must be something to separate 2000-2002 cranks from 2003, right?
They say that 23905-00A(2003) superseded 23905-00 (2000-2002?)
Old 17th July 2021
Hippysmack's Avatar
I added this to the above post but maybe not in time for you to see it.
I checked the parts books and flywheel assembly (23905-00) is the original assembly from 2000-2003.
On the parts books you have to look at the part number for the individual book to see what revision it is.
The -00 to -03 books say the -00 is the original assembly.
The -A, B or C parts books only show parts that were in production as replacements.
Online store's such as Ronnies and others all follow suit.
So the only way to find the original part numbers is to use the original parts books.
So the -00A wheel assembly is the replacement for the -00 assembly.
Now that being said, your rods have casting numbers ending in -02.
So the -00 flywheel assembly must have had different rods between 2000 and 2003.
But the assembly number didn't change.
This is truly par for the course with HD using different parts with the part numbers staying the same.
And it's another reason that we need more information on the different parts thru the years of this assembly since you couldn't buy individual parts for it after 1999.
Old 17th July 2021
Loks like that H-D did'nt care to make separate part number for just 2003 year production. All the 2000-2002 bikes that I had my hands on had older type of connrods and all of the 2003 bikes had thinner -02 rods on them.
Now, are they the same as 04 and up???
Old 17th July 2021
Hippysmack's Avatar
Ok, so one change in 03 was the rods were thinner. See the puzzle at hand.
I've been looking through the SIP and other documents in the pedia for more info on these year assemblies and coming up empty so far.
The problem is the MoCo sold the assembly only with no part numbers for the individual parts.
That leaves us guessing for the rest.
So I take your pics seriously as documentation of what parts were actually fitted to the assembly.
But we definitely need pics and info from further year assemblies and such to answer these questions.
In a previous post I added a link to the rocker box page.
You can see many many part number changes but looking at the actual parts, the casting numbers only changed a few times.
And of course the 07 oil pump that CLEARLY is not the same internals as the 06< but the part# is the same.
The parts books as much, as we need them for original part numbers, were never intended to nail down original part#s.
As far as I can tell, they were only intended to show parts that could be ordered for replacement that were in production at the time the book was written.
So that's where we come in to bridge that gap.
edit:
The -00A wheels would have to have timing marks to be able to replace previous rigid assemblies.
Rubbermount wheels don't have timing marks. The timing inspection hole was deleted and the original assembly has a -04 part number.
Did the rods change? I don't know yet.
But the part number change was due, at least in part, to the removal of the timing marks and the slotted edge wheels.
The slotted wheels are also found on the -00A assembly.
So it may be that the -00A assembly came about in or after 2004.
Flywheel assembly part numbers through 2013 currently are on the main page in the Sportsterpedia.
http://www.sportsterpedia.com/doku.p...wheel_assembly
Old 18th July 2021
Hippysmack's Avatar
This is why all this matters so much.
Here is an Ebay auction for Harley Davidson Sportster 1200 & 883 Engine Motor Crankshaft Crank Flywheel.
edit:
I gave the wrong and pic... fixed it.
https://www.ebay.com/itm/15429384967...IAAOSwRlNgAj8~
They didn't list what years it fits but there are no timing marks in these wheels.
Although at face value, it looks like the -00A assembly.
So we can save somebody some time and money if we can get all this cyphered out.
Old 18th July 2021
Smile
All I can say is that the bike in question is 2003 883R. Funny thing is, that it was a prize in Polish TV show and was won by the family that decided to sell it to split the profit and the lucky buyer was my brother The bike was completely stock and he rode it to UK where I live and we started the modifications. Most of it can be seen in my profile, this bike went under the serious modifications throughout it's life. But I remember the time when I stripped the top end down for the first time and I found out that the rods were way slimmer than mine, 2000 year model! I was working in a Harley custom shop in London UK at that time and I was familiar with them. So I can swear that the crank on the photos is from 2003 883R model!
Old 18th July 2021
I still think that this crank should be listed in the pedia, as to be fitted to ONLY 2003 year model, until somebody else will prove otherwise.
This is also the reason that I consider 2003 year model to be the best of all time
