0 First start question
0 It's Glamazon's Birthday!
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
  #4841
Old 30th September 2020
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
I think the guy might be dyslexic.
Looks to be right side shift engine. He might have meant 67 ? With some mods ? (Like the entire front end)
Nope it's a 76, RS brake lever and see the cable to the rear brake.
Blind Owl
Your probably right. My eyesight no longer allows me to see those details.
Why O why, if you were trying to sell something like this would you not know a bit more about it ?
10 minutes with Google would tell you so much.
Is he a scammer ? A liar ? or just plain bog stupid ?
I'm thinking about sending him an email explaining it's NOT the rare first year electric Sportster. Just a run of the mill 76 worth only $12 that I will buy from him if he pays the shipping.
Old 1st October 2020
SLW210 SLW210 is offline
Sportster/Buell Model: 1
Sportster/Buell Year: 2
SLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond repute
The shifter swaps were often done at the dealer back then, until they went to new cases for left side shift. Though this appears correct, they just have everything crossed for a few years.
Not sure where they got the first electric start deal. SMFH!!
mrmom9r's Avatar
mrmom9r mrmom9r is offline
mrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond reputemrmom9r has a reputation beyond repute
He probably got it the same place you got the fantasy about dealers swapping shifters side to side " back in the day".
Yeah that Idea sounds hinky. It's no simple task to swap sides, but more so because the dealer would be exposed to a huge liability.
Sportster/Buell Year #2: '03
^^^ for sure.federal mandate stated left side shift begining'75.what dealer would risk defying the Feds?
Old 2nd October 2020
DOT only applies to a manufacturer. Look it up in the history books. Like dealers don't and/or didn't bypass EPA either. Y'all got a lot to learn.
I didn't say it was all of them. Reading comprehension is piss poor on this site.
If any of y'all could use the internet....would have saved you the embarrassment...
https://duckduckgo.com/?q=right+shif...eos&iax=videos
Like stated it was a few years before they changed cases for the shifter swap so easy change.
