0 First start question
Last Post: Jaime1840
0 It's Glamazon's Birthday!
Last Post: 73HEAD
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 HSR idle mixture screw
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
  #5321
Old 13th September 2021
Opinions on the VIN/pad? Are the sixes legit?
On the plus side, Americans are learning the Greek alphabet.
spacecoast spacecoast is offline
Sportster/Buell Model: 883
Sportster/Buell Year: 1989
spacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant futurespacecoast has a brilliant future
Not Kosher.
Sportster/Buell Year #2: '03
can't see the vin pad?
ChinCactus's Avatar
In the link to the ebay auction.
ChinCactus's Avatar
https://www.ebay.com/itm/14419195619...AAAOSwhDRhOMwZ
Old 14th September 2021
post #45 shows the correct font for the security 6's and 9's used in '69 http://xlforum.net/forums/showthread...1862513&page=5 the 6's and 9's in the CL ad look like the letter P.
Old 15th September 2021
Sportster/Buell Year: 1969
When it comes to pre-VIN numbers if the vehicle has a clear title it does not matter what the number stamp looks like. To get the title the numbers had to be verified by the DMV as legitimate and not turn up stolen or totaled. Back in the day if a customer had a problem that required cases the dealer was often the one whom stamped the customers number on the replacement cases. Throughout the years Harley did this and that with no reason.
that's only in a perfect world with honest people.what if i had a legit bike blew up the motor and the cases.bought a stolen motor changed the numbers to match mine.no one had to approve those numbers.
Sadly we do not live in a perfect world. Evidence what is happening in the world this very minute. Even top officials lie under oath. I do not condone theft/crime. Iron head cases are 40+ years old these days. If DMV will put a title on it use it.
